صفحة 1 من 4 1 2 3 4 الأخيرةالأخيرة
النتائج 1 إلى 10 من 38
    الصورة الرمزية mavrck75
    رقم العضوية : 1590
    السيارة: gensis
    السيارة[2]: elantra
    دراجة بخارية: hgf
    الحالة : mavrck75 غير متواجد حالياً
    افتراضي اوعى تشترى هيونداى - Facebook Twitter whatsapp انشر الموضوع فى :
    نصيحة من واحد بيفهم فى العربيات أوعى تشترى هيونداى و خصوصا المانيوال
    بص يا سيدى الفتيس المانيوال فى أجيال هيونداى نفس التصميم فى Accent, Elantra, Getz, I30 And so on يعنى شوية دقيق و مية و شوية العجينة ممكن تطلع كحك و ممكن بسكويت أو ممكن بديفور.
    و هيونداى عندها عيب تصميم فى الدبرياج
    http://www.carsurvey.org/reviews/hyu...mments/page-3/
    المشاركة دى منقولة من الموقع و شوف الراجل بيعدل تصميم الدربرياج بتاع شركة هيونداى اللى هي المفروض تصنع عربيات لعب للأطفال
    2nd Aug 2009, 23:14
    I bought a 2008 Elantra with a slipping clutch up front. I repaired it myself. Car had 72,000 miles on it which I thought was low miles for a clutch problem.
    I am used to a clutch design having a release fork which is removable from the bellhousing, a return spring, and a push style release bearing pushing the clutch fingers forward for disengagement.
    This Elantra, however, has the release bearing moved by an arm integrated into the bellhousing supported by two plastic bearings. The release bearing snap locks into the clutch fingers and always rides the clutch fingers. Since the release bearing is locked to the clutch fingers, it is pulled back to disengage the clutch. Also the clutch mechanism has no return spring, so all of the return power comes from the clutch fingers.
    Dust as the clutch wears, got into the plastic bearings and increased the force needed to push the arm holding the release bearing back to its rest (clutch engaged) position.
    The clutch fingers have to push both: the release bearing against this increased shaft resistance and the back pressure resistance in the hydraulic fluid in the system. This increase in force bent my clutch fingers inward.
    To help stop this in the future, after replacing the clutch following a turned flywheel. I removed the slave cylinder fluid resistance by taking out a hydraulic orifice plate and spring, located right behind the fluid hose nut on the slave cylinder. Second, I determined where the clutch likes to rest when at rest (engaged). Welded an extension to the end of the slave cylinder clutch lever and attached a return spring to give assistance to the return of the clutch.
    I then welded a nut to the other end of the slave cylinder clutch lever and put a bolt through it, with a lock nut, to rest against the flat part of the transmission. This keeps the arm from being pulled back too far by the new return spring and the clutch arm always moves back to its rest position.
    As the clutch wears, a periodic adjustment will be necessary of this bolt to allow the clutch to fully engage since its zero point is now held by a bolt adjustment.
    This design has been done on a few other models of cars I've owned so only time will tell if this Elantra will like it.
    Note: This will slightly increase the pedal resistance of the clutch pedal during shifting. Spring pulls back about 5 lbs so it is hardly felt.
    صدقتونى
    Hyundai has a baaaaaaaaaaaad clutch design
    الصورة الرمزية ashouhdy
    رقم العضوية : 36989
    الاقامة : Alexandria
    السيارة: كروز 2014
    السيارة[2]: Car Enthusiaset
    دراجة بخارية: :))
    الحالة : ashouhdy غير متواجد حالياً
    مع صحبى اكسينت من سنة 99 مغيرتش اسطوانة !
    وانا معايا من سنتيين و ذى الفل
    و خالى عملة 280 الف كيلو و بتأمرك !!
    مش اى حاجة مكتوبة بالانجليزى تصدقها يأستاذى :)))))
    اللى حيضيع بلدنا : الفهلوة و كلمة باشا و معلش و أصل
    الصورة الرمزية amr.elsayed
    رقم العضوية : 32825
    الاقامة : alex
    السيارة: Lanos 2016
    السيارة[2]: Logan 2010..Elantra 2014
    دراجة بخارية: ..............
    الحالة : amr.elsayed غير متواجد حالياً
    هى عربيات هيونداى دى نزلت مصر امبارح مثلا دى عربيات موجودة من سنين
    بالنسبة للشخص اللى بيعدل دة فمش اى حد نسمع كلامه وخلاص
    الصورة الرمزية kliken
    رقم العضوية : 21551
    الاقامة : suez
    السيارة: الحمد لله كده زى الفل
    السيارة[2]: Nissan Tiida H/B
    الحالة : kliken غير متواجد حالياً
    كلام مش منطقى طبعا انا معايا النترا و عديت ال 100 الف كيلو و ما شاء الله زى الفل و ليا اصحابى معدين بيها ال 200 الف و لا فيها اى كلام من اللى حضرتك بتقوله مش لدرجه عربيات اطفال يعنى
    م / محمد سعد
    [img2]http://img846.imageshack.us/img846/197/63588414414249233311774.jpg[/img2]
    الصورة الرمزية Nile_Storm
    رقم العضوية : 3233
    الاقامة : El Haram
    السيارة: FSO Polonez 1990
    السيارة[2]: Hyundai Verna 2008 LS
    الحالة : Nile_Storm غير متواجد حالياً
    لو كانت كده مكنتش قعدت ده كله في مصر
    ولا نجحت كده و لا نتشرت كده
    و ليس كل ما يكتب بالانجليزيه حقائق يا باشا
    الصورة الرمزية KSA2011
    رقم العضوية : 43413
    الاقامة : Elmansoura City
    الحالة : KSA2011 غير متواجد حالياً
    thanx
    الصورة الرمزية mr_sameh
    رقم العضوية : 48080
    الاقامة : 6 اكتوبر
    السيارة: مفيش
    السيارة[2]: مرسيدس
    الحالة : mr_sameh غير متواجد حالياً
    انا اخويا راكب اكسيل وكان عندو مشكلة في الغيار التالت ولما سئل قالو ان فتيس الاكسيل كلو في مشكلة في الغيار التالت بس بصراحة ماشوفتش اي هيونداي في مشكلة في الفتيس
    الصورة الرمزية aymansaad
    رقم العضوية : 19101
    الاقامة : السويس
    السيارة: فيات131
    السيارة[2]: فيات125
    دراجة بخارية: vesba
    الحالة : aymansaad غير متواجد حالياً
    بصراحة الهيونداى اثبتت كفاءة فى مصر
    الصورة الرمزية ahmedkoko
    رقم العضوية : 8135
    الاقامة : Zurich
    السيارة: sold
    السيارة[2]: Toyota Avensis 2.0 2009
    الحالة : ahmedkoko غير متواجد حالياً
    بصراحه انا بحترم هيونداي جدا لان اي عربيه تثبت كفاءه في مصر تبقي عربيه جباره. احنا في بلد مفيهاش شارع تعرف تمشي فيه ده غير الحر الشديد جدا و كميات التراب المهوله اللي تسد اجدعها فلاتر. هيونداي عدت من كل ده يبقي اكيد عربيه محترمه.
    وبحبك وحشتيني
    الصورة الرمزية dr_abooody
    رقم العضوية : 11647
    الاقامة : EL-ma3adi
    السيارة: FIAT 128
    السيارة[2]: Hyundai elantra M\T 2009
    الحالة : dr_abooody غير متواجد حالياً
    و كان رئيس شركة هوندا و نيسان اعدين يقولوا هيونداي مذهلة هيونداي هتسبقنا
    فعلا هيونداي بقت الرابع على العالم في المبيعات لانها رخيصة و عملية و اقتصادية
    [mtohg=#ff0000]http://img862.imageshack.us/img862/4429/hyundaielantra201208.jpg[/mtohg]
  1. مشاركات: 57
    آخر مشاركة: 09-09-2012, 07:18 PM
  2. اوعى تشترى وكيل
    بواسطة mido في المنتدى كـــــيا
    مشاركات: 15
    آخر مشاركة: 23-01-2012, 09:03 PM
  3. مشاركات: 25
    آخر مشاركة: 15-07-2011, 07:37 AM
  4. احذر - تسلم ( اوعى تشترى اى عربية مستعة قبل ماتدخل الموضوع دا ) تنبية هاام
    بواسطة fox26 في المنتدى قســم خاص لبيع السيارات فقـــط
    مشاركات: 34
    آخر مشاركة: 24-08-2010, 06:39 PM
  5. اوعى تشترى فيات لو أنت من إسكندرية
    بواسطة m_abdelfattah في المنتدى فــــيات
    مشاركات: 24
    آخر مشاركة: 19-08-2009, 11:13 AM
