انا من الـ5% اللى نجحت فى اجابه الاسئله وعلى فكره الاجابه بتاعت السؤال الخامس نور الشريف
رقم العضوية : 2282
الاقامة : Cairo ,Faisal st
السيارة: كانت lada 2107 1989
السيارة[2]: Daewoo Nubira2 2005 auto
[info]copied from my e-mail inbox[/info]
It's that time of year to take our annual check-up test.
Exercise of the brain is as important as exercise of the muscles. As we grow older, it's important to keep mentally ...... If you don't use it, you lose it! Below is a very private way to gauge your loss or non-loss of intelligence.
Take the test presented here to determine if you're losing it or not. The spaces below are so you don't see the answers until you've made your answer.
OK, relax, clear your mind and begin.
1. What do you put in a toaster?
Answer: 'bread.' If you said 'toast,' give up now and do something else.
Try not to hurt yourself. If you said, bread, go to Question 2.
2. Say 'silk' five times. Now spell 'silk.' What do cows drink?
Answer: Cows drink water. If you said 'milk,' don't attempt the next question. Your brain is over-stressed and may even overheat. ....... yourself with reading a more appropriate literature such as Auto World. However, if you said 'water', proceed to question 3.
3. If a red house is made from red bricks and a blue house is made from blue bricks and a pink house is made from pink bricks and a black house is made from black bricks, what is a green house made from?
Answer: Greenhouses are made from glass. If you said 'green bricks,' why in the world are you still reading these???
If you said 'glass,' go on to Question 4.
4.. It's twenty years ago, and a plane is flying at 20,000 feet over Germany (If you will recall, Germany at the time was politically divided into West Germany and East Germany.)
Anyway, during the flight, two engines fail. The pilot, realizing
that the last remaining engine is also failing, decides on a crash landing procedure. Unfortunately the engine fails before he can do so and the plane fatally crashes smack in the middle of 'no man's land' between East Germany and West Germany. Where would you bury the survivors? East Germany, West Germany, or no man's land'?
Answer: You don't bury survivors.
If you said ANYTHING else, you're a dunce and you must stop. If you said, 'You don't bury survivors', proceed to the next question.
5. Without using a calculator - You are driving a bus from Lon don to Milford Haven in Wales. In London, 17 people get on the bus. In Reading, six people get off the bus and nine people get on. In Swindon, two people get off and four get on. In Cardiff, 11 people get off and 16 people get on. In Swansea, three people get off and five people get on
. In Carmathen, six people get off and three get on. You then arrive at Milford Haven.
What was the name of the bus driver?
Answer: Oh, for crying out loud!
Don't you remember your own name? It was YOU!!
Now pass this along to all your friends and pray they do better than you.
PS: 95% of people fail most of the questions!!
قول الرسول صلى الله عليه وسلم: "خير النساء من إذا نظرت إليها سرتك، وإذا أمرتها أطاعتك، وإذا أقسمت عليها أبرتك، وإذا غبت عنها حفظتك في نفسها ومالك"
-- اللهم ارزقنيها --
رقم العضوية : 25425
السيارة: 1
السيارة[2]: 1
رقم العضوية : 29762
الاقامة : Faysal-Giza
السيارة: NA
السيارة[2]: Toyota echo 2000 HB
انت نسيت تقول انها لي . اصعدي الي فوق
