مواصفات Verna 1600
- ENGINE & TRANSMISSION Technology VTVT - Variable Timing Valve Train
Valve & Cam arrangement 16V - DOHC
Displacement (cc) 1599
Max. Power (ps/rpm) 103.2 / 5500
Max. Torque (kgm/rpm) 14.9 / 3000
Transmission 5 Speed Manual
STEERING Type Power assisted Rack & Pinion
Minimum Turning Radius (m) 4.92 (5.05)
SUSPENSION Front Suspension MacPherson Strut with coil springs and anti roll bar
Rear Suspension Coupled torsion beam axle
Shock Absorbers Gas type
BRAKES Front Brakes Ventilated Discs
Rear Brakes Drum / Disc (ABS)
DIMENSIONS Overall Length x Width x Height (mm) 4310 x 1695 x 1490
Wheelbase (mm) 2500
Ground Clearance (mm) 170
Fuel Tank Capacity (L) 45
شكراااااااااااااااااااااا ااااااااااااااااا
Content Relevant URLs by
vBSEO 3.6.0 PL2
