رقم العضوية : 143
الاقامة : Nasr City
السيارة: Toyota Yaris 2007
السيارة[2]: Nissan Juke 2013
The technology found in the Murciélago LP640 has not been modified. The engine in the LP640 forwards is the classic twelve-cylinder engine with 6.5 litre displacement. Only for this car, Lamborghini guarantees, an astounding 650 HP (478 kW) at 8,000 revolutions per minute (rpm). The huge torque, equal to maximum 660 Nm, ensures a powerful switch from any number of revolutions: even the slightest pressure on the accelerator is spontaneously transformed into thrust. The robotised e.gear changes gear faster than even the most expert driver. In addition, the permanent Viscous Traction four-wheel drive system ensures that every force is constantly translated into movement.
As in the original Murciélago LP640, the Reventón accelerates from 0 to 100 km/h in just 3.4 seconds, with a maximum speed over 340 km/h.
Lamborghini Reventón - Technical data
Frame
High strength tubular steel structure with carbon fibre components.
Bodywork
In carbon fibre, except roof and door external panels (steel)
Steering
Type: Mechanical (rack and pinion) power-assisted
Right-hand turning circle: 12.55 m (41.17 ft)
Wheels and tyres
Front: 245/35 ZR 18
Rear: 335/30 ZR 18
Engine
Type: 12 cylinders at 60°
Bore and stroke: 88 mm x 89 mm (3.46 in x 3.50 in)
Displacement: 6496 cc (396.41 in3)
Compression ratio: (11 ± 0.2):1
Maximum power: 650 HP (478 kW) at 8000 rpm (guaranteed through the engine selection)
Maximum torque: 660 Nm (487 lb-ft) at 6000 rpm
Engine position in vehicle: Longitudinal central-rear
Cylinder heads and engine block: Aluminium
Intake system: Variable geometry with 3 operating modes
Performance data
Top speed: 340 km/h (211.3 mph)
Acceleration 0-100 km/h (0-62 mph): 3.4 s (before: 3.8 s)
Fuel Consumption (according to DIR 1999/100/CE)
Urban: 32,3 l/100km
Extra-urban: 15,0 l/100 km
Combined: 21,3 l/100 km
CO2 emissions: 495 g/km
رقم العضوية : 475
الاقامة : الأسكندرية
السيارة: I30 & Megane estate
السيارة[2]: E36 Coupe 328i
دراجة بخارية: .
رقم العضوية : 1288
الاقامة : Cairo,Egypt
السيارة: , c4 2005LANOS 2006
السيارة[2]: opel vectra B 2000cc 1997
no comment
Opel : 1 Team , 1 Family , 1 Goal
حرااااااااااااااااااااااا ااااااااااااااااااااااااا ااااااااااااااااااااااااا ااااااااااااااااااااااااا ااااااااااااااااااااااااا اااااااااااام
http://www.postimage.org/PqJgCQ0.jpg
