السلام عيكم
انا فاكر يا جماعه كنا اتكلمنا قبل كده ازاى نحمى العربيات من السرقه
باستخدام وحده GPS ورسيفر او حتى برنامج على الموبايل او البى سى بس ده بأشتراك
المهم لسه حالا واحد عندنا فى الشارع عربيته اتسرقت كلها كده على بعضها
ومنظر الراجل وهو بيجرى يمين وشمال وبزعق عربيتى اتسرقت عربيتى اتسرقت
يصعب على الكافر
على الفور عملت جوله على الانترنت وقلت اشوف فكره الـ GPS دى الى فكرنا فيها احنا هنا من مده
للاسف عملت ما فى استاطعتى علشان اى موقع عربى كاتب عن الموضوع ملقتش
وكلمه جى بى اس فى اى موقع عربى متلقيش غير موبيلات!!
بس المواقع الاجنبيه مليئه بالمعلومات عن الحكايه دى
ودا كلام خبير حمايه اسمه Jim Wilkinson
زى القمر اهو
انتم عارفين الناس دى مهمه اوى عندهم
ومفيش حد عنده منزل الا لازم انه يستعين بخبير حمايه يساعده على حمايه المنزل
انذار هنا...باب حديد هنا...كده
المهم خلينا فى موضوعنا ده كلام Jim Wilkinson
One of the worst feelings in the world is walking back to where you parked your car and finding it gone. If you have a really nice car that is your pride and joy or just a very expensive vehicle, then you should consider using a WorldTracker GPRS Extreme or another type of GPS device. If you use a GPS real-time locating device you can protect your car with a good probability of reducing damage by being immediately notified of the theft by an automatic alarm, real time tracking, and a GPS is very reliable.
When you use a GPS real time tracking system with your car then you have the ability to know where your car is at all times. They work in real time. This means that they are updated every 15 seconds or so as the vehicle is moving down the road. If someone steals your car they won't make it very far before you have located your vehicle and can have the police go retrieve it. A WorldTracker GPRS Extreme is an excellent GPS that has an integrated alarm system in it. You can receive an alarm signal from the moment the car begins to move out of the parking spot. This means that the thief may not get too far because you will know the moment they begin to move. If you suspect your children are sneaking the car out at night when you go to bed a GPS is the best thing you can use to prevent that from happening.
فواضح انه ذكر unit معينه من الـ GPS وهى WorldTracker GPRS Extreme
على الفور سيرش عنه واليكم.الاتى
همه كاتبين عنه انه The first tracking device with real-time updates
every 15 seconds Direct GPRS data
New WorldTracker GPRS, the first tracking device with real-time updates every 15 seconds. Direct GPRS data connection gives you the most accurate and reliable tracking data ever! The entire functioning unit is as small as a set of car keys. Tiny, accurate, discreet, and reliable. The next generation of GPS tracking is here.
The WorldTracker GPRS is a self-contained complete hardware and software package small enough to fit in the palm of your hand. When placed with packages, vehicles, or personnel, the WorldTracker GPRS provides detailed reports of routes traveled for quality-control and security purposes.
Featuring SiRF star III technology for extra sensitive reception outdoors, indoors and through ....l. WAAS enabled receiver providing GPS signal corrections, giving better position accuracy. How much better? Try an average of up to five times better. A WAAS-capable receiver can give you a position accuracy of better than three meters 95 percent of the time.
WorldTracker GPRS provides real-time navigation in urban canyons as well as high sensitivity acquisition needed for indoor use.
وادى الفيتشرز
WorldTracker GPRS Features
Self contained device fits in the palm of your hand. No external antennae needed, just plug-&-play.
Location information is reported using a direct GPRS data connection.
Mapping for the entire world using the latest cutting edge 3D maps from Google and Microsoft.
Real-time location reports every 15 seconds.
Geofence feature sends ..... if the target moves from pre-defined area.
Parking and Anti-theft Function: Pressing the Parking Button will start the anti-theft function. If your vehicle has been moved 100 meters the WorldTracker will send messages to the pre-set phone numbers to warn you of the vehicle movement.
GPS assist function using GSM network, boosting location sensitivity when GPS signal is temporarily lost.
Durable, lightweight, water-resistant housing.
Enhanced sensitivity for indoor and outdoor reporting.
Tri-band GSM 850/1800/1900 MHz for worldwide coverage.
12 volt DC adapter connects to vehicle power.
Can be hooked up to 12 volt DC for permanent hardwire connection
ودى صوره بيقلك قال بص يعنى دا صغنن اد المفتاح
والمفروض انه بتحط فى اى حته فى العربيه من الافضل يكون مستخبى
انما عندنا حتى لو حد شافه مش هيعرف دا ايه
السعر فى الموقع ده
389$
[info]اخيرا ياااااااااااا ريت يا جماعه كلنا نحاول نعرف حد بيبيعه فى مصر
وازاى بيتركب بالظبط
وحكايه الاشتراك دى علشان لما كنا بندرسه فى الكليه كان معاك يونت و رسيفر متبقاش عايز حاجه من حد
وانا هسئل مهندسين المساحه الى اعرفهم[/info]
و شكراً
