أتفضل يا هندسه السطر الأول رقم و أسم العطل و السطر التانى أحتمال مسببات العطل
1
Engine control module (ECM)/transmission
control module (TCM) - TPS signal low Wiring, ECM/TCM
2 Engine control module (ECM)/transmission
control module (TCM) - TPS signal high Wiring, ECM/TCM
3 Engine coolant blower motor relay 2 -
circuit low Wiring, engine coolant blower motor relay(s), ECM
4 Engine coolant blower motor relay 2 -
circuit high Wiring, engine coolant blower motor relay(s), ECM
5 Engine coolant blower motor relay 1 -
6 Engine coolant blower motor relay 1 -
7 Exhaust gas recirculation (EGR) solenoid -
voltage low Wiring short to earth, EGR solenoid, ECM
8 Exhaust gas recirculation (EGR) solenoid -
voltage high Wiring short to positive, EGR solenoid
13 Oxygen sensor (O2S) - malfunction Wiring, O2S, ECM
14 Engine coolant temperature (ECT) sensor
- high temperature detected Wiring, ECT sensor, ECM
15 Engine coolant temperature (ECT) sensor
- low temperature detected Wiring, ECT sensor, ECM
16 Knock sensor (KS) 1 - signal Wiring, KS, ECM
17 Injector(s) - circuit malfunction Wiring, injector(s), ECM
18 Engine control module (ECM) - KS control Wiring, KS, ECM
19 Crankshaft position (CKP) sensor -
incorrect signal Mechanical fault, air gap, wiring, CKP sensor, ECM
21 Throttle position (TP) sensor - voltage high Wiring short to positive, TP sensor, ECM
22 Throttle position (TP) sensor - voltage low Wiring short to earth, TP sensor, ECM
23 Intake air temperature (IAT) sensor -
voltage high Wiring, IAT sensor, ECM 24
1
Vehicle speed sensor (VSS) - incorrect
signal
Wiring, VSS, ECM
24
2
signal
Wiring, VSS, TCM, ECM
25 Intake air temperature (IAT) sensor -
voltage low Wiring, IAT sensor, ECM
27 AC pressure sensor - high input Wiring, AC refrigerant pressure sensor, ECM
28 AC pressure sensor - low input Wiring, AC refrigerant pressure sensor, ECM
29 Fuel pump (FP) relay - voltage low Wiring, FP relay, ECM
32 Fuel pump (FP) relay - voltage high Wiring, FP relay, ECM
33 Manifold absolute pressure (MAP) sensor -
signal high Wiring, hose blocked/leaking, MAP sensor, ECM
34 Manifold absolute pressure (MAP) sensor -
signal low Wiring, hose blocked/leaking, MAP sensor, ECM
35 Idle air control (IAC) valve Wiring, IAC valve, intake air leak, fuel system, mechanical fault, ECM
41 Engine control module (ECM), ignition
signal cyl. 2 & 3 - voltage high Wiring, ignition coil/amplifier, ECM
42 Engine control module (ECM), ignition
signal cyl. 1 & 4 - voltage high Wiring, ignition coil/amplifier, ECM
44
Oxygen sensor (O2S) - mixture lean Wiring, injector(s) blocked, fuel contamination, fuel pressure low, exhaust
system leak, O2S, ECM
45 Oxygen sensor (O2S) - mixture rich
Wiring, fuel pressure high, injector(s) leaking, O2S contamination,
evaporative emission (EVAP) canister purge valve, throttle position (TP)
sensor, EGR system, O2S, ECM
49 Battery supply voltage - high Wiring, alternator, regulator, ECM
51
Engine control module (ECM) - PROM Insecure PROM, incorrect PROM, ECM
53 Engine control module (ECM) - immobilizer
active
Incorrect/damaged key, incorrectly coded, ECM/immobilizer replacement
without coding, wiring, immobilizer defective, ECM
55
Engine control module (ECM) - defective ECM
61
Evaporative emission (EVAP) canister
purge valve - voltage low Wiring short to earth, EVAP canister purge valve, ECM
62 Evaporative emission (EVAP) canister
purge valve - voltage high Wiring short to positive, EVAP canister purge valve, ECM
63 Engine control module (ECM), ignition
signal cyl. 2 & 3 - voltage low Wiring, ignition coil/amplifier, ECM
64 Engine control module (ECM), ignition
signal cyl. 1 & 4 - voltage low Wiring, ignition coil/amplifier, ECM
87 AC compressor clutch relay - voltage low Wiring, AC compressor clutch relay, ECM
88 AC compressor clutch relay - voltage high Wiring, AC compressor clutch relay, ECM
93
3
Engine control module (ECM), quad driver Wiring, ECM controlled components, ECM
