النتائج 1 إلى 2 من 2
    الصورة الرمزية Horsepower
    رقم العضوية : 22739
    السيارة: Toyota Avensis 2008
    السيارة[2]: Honda Civic LXi 2009
    دراجة بخارية: N/A
    الحالة : Horsepower غير متواجد حالياً
    Smile Vehicle Stability Assist (VSA) - Honda - Facebook Twitter whatsapp انشر الموضوع فى :
    السلام عليكم,
    هذا الموضوع منقول
    وهو عن نظام مساعد ثبات السيارة و الخاص بسيارات هوندا بكل تفاصيله
    أرجو أن يكون مفيدا للجميع
    Vehicle Stability Assist Development Objectives
    Tokyo, July 2, 1997 --- From the early days, Honda has looked atmeans to increase active safety. It was the first to offer a four-wheelanti-lock brake (ABS) system in Japan, and the first in the world tosuccessfully develop a traction control system for front wheel drivevehicles.
    The Vehicle Stability Assist (VSA) system we are introducingtoday adds side slip control to ABS and TCS systems. This new system controlssudden changes in vehicle behavior, giving the driver the time to keep controlof the situation. When driving in the rain or on snow, the system stabilizes thevehicle, reducing counter-productive driver tension.
    In order not to spoil driving pleasure we have devised a uniquesystem based on the concept of "vehicle stabilization through control of thefront wheels". VSA is a simple, reliable system enhancing performance anddriving pleasure.
    - the rear wheels slip sideways, resulting in a sudden change inheading toward the inside (spin) = oversteer.
    - the front wheels slip sideways, resulting in a wider corneringline = understeer
    1) Oversteer control:
    By braking the outer front wheel, an outward moment isgenerated. The cornering force at the front is thus reduced, decreasing the spingenerating moment and stabilizing vehicle behavior
    * Detection and Control
    The yaw rate intended by the driver (target yaw rate) iscalculated according to lateral acceleration, steering angle and vehicle speed. If the actual yaw rate exceeds the target, the VSA system brakes the outsidefront wheel to reduce yaw. Brake Application to Outer Front Wheel = Oversteer Control
    2) Understeer control when cornering under power
    When the car's cornering line widens under excessive throttleapplication, the system intervenes by reducing engine torque and, if necessary, by braking the inside front wheel. This creates an inward moment helping the cartrace the line originally intended by the driver
    The yaw rate intended by the driver (target yaw rate) iscalculated using steering angle and vehicle speed. If the actual yaw rate isbelow target, the system intervenes to reduce engine power and increase yawrate. If necessary, the system will also brake the inner front wheel.
    Engine Torque Reduction + Inner Front Wheel Braking = Understeer Control When Cornering Under Power
    3) Standing Start Slip Control
    When accelerating on a split surface with different gripcoefficients, engine torque is usually transmitted to the wheel with the lowestgrip level, resulting in traction loss. By braking the wheel with the lowestgrip, greater torque is provided to the wheel on the other side, ensuring quick, powerful acceleration
    4) Braking control under cornering
    When high cornering forces are detected, ABS automaticallyswitches to the 4-channel mode (3-channel mode when in a straight line or whencornering at lower speeds). Taking advantage of the weight transfer duringcornering, the system applies a higher brake pressure on the outer rear wheel, improving braking performance
    System Configuration and Principal of Operation
    و شكراً...
    أحمد سامي
    الصورة الرمزية Honda_lover
    رقم العضوية : 28707
    الاقامة : 10th of ramadan city
    السيارة: citroen c4 2013
    السيارة[2]: citroen xsara 1
    الحالة : Honda_lover غير متواجد حالياً
    شكرا على المعلومات
    https://www.facebook.com/GearOneForCarAccessories
  1. مشكلة فى شاشة الجيتا setup only when vehicle is stationary
    بواسطة body في المنتدى ورشـــة نــايل مــــوتـــورز
    آخر مشاركة: 04-06-2011, 10:41 PM
  2. ملوك الـ Stability
    بواسطة Eng.Osama.Afifi في المنتدى المنتــــــدى الاجتمــاعى
    آخر مشاركة: 25-06-2010, 10:53 PM
  3. Vehicle Graphics** أستيكرات **اصنعها بنفسك**
    بواسطة M.Elwan في المنتدى كــماليــات السيـــارات و الإكسسوارات
    مشاركات: 28
    آخر مشاركة: 07-03-2010, 01:52 AM
  4. Impreza Gets Japan Safest Vehicle Award
    بواسطة vet mitcho في المنتدى ســوبارو
    آخر مشاركة: 25-04-2008, 02:40 AM
  5. yaris stability
    بواسطة mohamed ibiza في المنتدى تـويوتـــا
    مشاركات: 20
    آخر مشاركة: 04-01-2008, 02:55 PM
#2, 07, 11, 12, 13, 14, 15, 16, 17, 18, 19, 199, 1997, 20, 52, 70, 97, 99, للجميع, لموضوع, ab, abl, abs, acc, acceleration, accord, action, active, ad, adv, af, لجميع, aig, ليك, ليكم, aki, al, ally, ana, أرجو, ans, anti, مساع, مساعد, لسيارة, app, art, assist, aut, auto, automatic, avio, aw, مفيد, له, من, موضوع, منقول, ba, bas, base, bel, bm, bra, brake, brakes, braking, bs, ام, الموضوع, الخاص, call, السلام, السيارة, car, cc, ceed, center, change, channel, ck, cl, ار, col, color, concept, contro, control, controls, cr, d3, da, day, days, de, dec, development, di, din, dr, drive, driver, driving, ds, du, dv, ease, با, ثبات, eh, el, eli, ems, eng, engin, engine, enhancing, enter, بس, بسيارات, er, es, ev, تفاصيل, بكل, f5, fa, face, fe, ff, fi, fo, font, force, forces, forman, front, full, fully, gen, gin, gina, giving, gl, gr, great, grip, head, high, hond, honda, hr, http, جميع, يا, خاص, ide, il, image, increase, inside, intro, ip, iq, ir, iv, يكون, japan, je, kee, king, la, le, li, line, lip, ll, lock, loss, low, lower, lp, ls, lt, mag, man, matic, means, men, mg, mo, mod, mode, mp, ms, news, nf, ng, od, offer, سيار, سيارات, سيارة, oil, opera, operation, order, original, ot, oversteer, ovi, شكر, شكرا, شكراً, performance, pm, power, powerful, pp, pre, pressure, pro, pt, quick, ra, race, ratio, rc, rear, red, reduce, reduced, ring, rm, rom, ron, rs, safe, safety, se, si, side, simple, sl, snow, speed, speeds, split, ss, st, stability, star, start, steering, sudden, sw, switch, sys, system, systems, tab, tag, tc, te, throttle, ti, time, times, today, tokyo, torque, traction, transm, tsi, tt, عليك, عليكم, uc, عد, understeer, ur, عن, van, vantage, vehicle, vehicles, vel, vi, vid, vin, vsa, wa, war, west, wheel, wheels, wide, world, ya, فا, في, هذ, هذا, هو, هوندا, ول, نظا, نظام, ون, وندا, قول, كل
عرض سحابة الكلمة الدلالية
