النهاردة كنت عند الطارق (سيتي سنتر الإسكندرية) وشوفت رانجلر الجديدة سعرها 240 ألف
بس بصراحة فاجرة , ونقلة كبير عن الشكل القديم بالذات من حيث الوسع و طول الشاسية تقريبا بقيت قد الهامر H3
وأدي صورة بتبين حجمها بالنسبة للجراند شيروكي
http://www.drivearabia.com/news/wp-....d-Cherokee.jpg
http://d.yimg.com/ca.yimg.com/autos/...2010-5OD-4.jpg
http://fp.images.autos.msn.com/meris...ry/6293_37.jpg
http://fp.images.autos.msn.com/meris...ry/6293_50.jpg
http://www.jeep.com.eg/2009/wrangler...r-interior.jpg
http://www.jeep.com.eg/2009/wrangler...ler-safety.jpg
ENGINE
Engine Order Code
EGT
Engine Type
Gas V6
Displacement
3.8L/231
Fuel System
SMPI
SAE Net Horsepower @ RPM
205 @ 5200
SAE Net Torque @ RPM
240 @ 4000
TRANSMISSION
Drivetrain
2-Wheel Drive
Trans Order Code
DGV
Trans Type
4
Trans De......ion Cont.
Automatic
First Gear Ratio (:1)
2.84
Second Gear Ratio (:1)
1.57
Third Gear Ratio (:1)
1.00
Fourth Gear Ratio (:1)
0.69
Reverse Ratio (:1)
2.21
Final Drive Axle Ratio (:1)
3.73
MILEAGE
Fuel Economy Est-Combined (MPG)
17 (2009)
EPA Fuel Economy Est - City (MPG)
15
EPA Fuel Economy Est - Hwy (MPG)
20
ELECTRICAL
Cold Cranking Amps @ 0° F (Primary)
600
Maximum Alternator Capacity (amps)
140
COOLING SYSTEM
Total Cooling System Capacity (qts)
13.4
WEIGHT INFORMATION
Base Curb Weight (lbs)
4100
TRAILERING
Dead Weight Hitch - Max Trailer Wt. (lbs)
3500
Dead Weight Hitch - Max Tongue Wt. (lbs)
350
Wt Distributing Hitch - Max Trailer Wt. (lbs)
3500
Wt Distributing Hitch - Max Tongue Wt. (lbs)
525
SUSPENSION
Suspension Type - Front
Live Axle
Suspension Type - Rear
Live Axle
Suspension Type - Front (Cont.)
w/Coil Springs
Suspension Type - Rear (Cont.)
w/Coil Springs
Shock Absorber Diameter - Front (mm)
- TBD -
Shock Absorber Diameter - Rear (mm)
- TBD -
Stabilizer Bar Diameter - Front (in)
- TBD -
Stabilizer Bar Diameter - Rear (in)
- TBD -
BRAKES
Brake Type
Power
Brake ABS System
4-wheel
Disc - Front (Yes or )
Yes
Disc - Rear (Yes or )
Yes
Front Brake Rotor Diam x Thickness (in)
11.9 x 1.1
Rear Brake Rotor Diam x Thickness (in)
12.4 x 0.5
TIRES
Front Tire Order Code
TRM
TUF
Rear Tire Order Code
TUF
TRM
Spare Tire Order Code
TBB
Front Tire Size
P225/75R16
Front Tire Size
P255/75R17
Rear Tire Size
P255/75R17
Rear Tire Size
P225/75R16
Spare Tire Size
P225/75R16
Spare Tire Size
P255/75R17
WHEELS
Front Wheel Size (in)
16 x 7.0
17 x 7.5
Rear Wheel Size (in)
17 x 7.5
16 x 7.0
Spare Wheel Size (in)
16 x 7.0
17 x 7.5
Front Wheel Material
Steel
Aluminum
Rear Wheel Material
Steel
Rear Wheel Material
Aluminum
Spare Wheel Material
Steel
Aluminum
STEERING
Steering Type
Power
Steering Ratio (:1), Overall
14.7
Lock to Lock Turns (Steering)
3.5
Turning Diameter - Curb to Curb (ft)
41.2
Turning Diameter - Wall to Wall (ft)
- TBD -
FUEL TANK
Fuel Tank Capacity, Approx (gal)
22.5
EXTERIOR DIMENSIONS
Wheelbase (in)
116.0
Length, Overall (in)
173.4
Width, Max w/o mirrors (in)
73.9
Height, Overall (in)
- TBD -
70.8
Track Width, Front (in)
61.9
Track Width, Rear (in)
61.9
Min Ground Clearance (in)
10.0
8.7
Rear Door Opening Height (in)
37.1
Rear Door Opening Width (in)
58.7
Liftover Height (in)
31.4
CARGO AREA DIMENSIONS
Cargo Area Length @ Floor to Seat 1 (in)
- TBD -
Cargo Area Length @ Floor to Seat 2 (in)
- TBD -
Cargo Area Width @ Beltline (in)
- TBD -
Cargo Box Width @ Wheelhousings (in)
44.7
Cargo Box (Area) Height (in)
- TBD -
Cargo Volume to Seat 1 (ft³)
86.8
Cargo Volume to Seat 2 (ft³)
46.4
INTERIOR DIMENSIONS
Passenger Capacity
5
Passenger Volume (ft³)
103.9
Front Head Room (in)
41.3
Front Leg Room (in)
41.0
Front Shoulder Room (in)
55.8
Front Hip Room (in)
55.6
Second Head Room (in)
40.4
Second Leg Room (in)
37.2
Second Shoulder Room (in)
56.8
Second Hip Room (in)
56.7
