اسعار قطع غيارالواجا الجديدة فى ماليزية للعلم
FOB (RM) Headlamp Bosch Original (per Side) 278.00 TailLamp Bosch Original (per Side) 105.00 FogLamp Bosch Original ( per side) 195.00 Waja Local door handle- r piece 11.00 Waja coloured door handle- according to ur original colour-r 28.00 Waja Side Mirror- Local per side 168.00 Exedy clutch kit set for Waja 1.6- 248.00 Brake Pad. Bendix ....l King Titanium (front), (rear) F 98.00 R 92.00 Brake Pad. Mintex from UK. front R 58.00 R 58.00 ProtonBrake Pad- front Bosch ( 1 pair) 45.00 FBKBrake Pad- rear Bosch ( 1 pair) 45.00 FBKWaja Window regulator-....l one front 128.00 local back 158.00 Waja original proton power window motor- front, rear per side 48.00 Taiwan (TW)Waja Timing belt Gates- (full warranty 178.00 PowerTiming Belt Dayco(Europe) 60.00 belt onlyBosch timing belt kiot set - complete setBosch timing belt kit - complete setAdd air-con, fan belt dayco 28.00 BandoWaja 1.6 top overhaul set Original Proton (many fakes out there) 188.00 SOWAWaja 1.6 overhaul set Original Proton (many fakes out there) 238.00 SOWAWaja 1.6 front wheel bearings (per side)SKF Brand + oil seal 65.00 NTNrear wheel bearings (per side) 135.00 Waja 1.6 throttle body- Original ProtonWaja 1.6 fuel pump Original Proton 380.00 Waja 1.6 brake master pump proton edar selling TW 98.00 210.00 Waja 1.6 brake booster Original Proton 430.00 Waja 1.6 steering (with 2 buttons complete) Original Proton Waja 1.6 power window switch main 98.00 Waja 1.6 wiper switch 158.00 Waja 1.6 wiper motor-Original Proton 210.00 Engine mounting 1.6 (auto/manual) total 4cps.. Original proton F/R 58.00 LH/RH 135.00 Waja 1.6 front & rear bumper Original Proton per sideAPM coil spring normal size-front rear per side F 65.00 R 55.00 TWWaja 1.6 original driveshaft whole batang per side Ori 298.00 TW 178.00 Waja 1.6 bonnet Original Proton (grey)-, add nose Ori 330.00 TW 220.00 Waja 1.6 fender/mudguard front Original Proton per side (grey) Ori 110.00 TW 76.00 Waja fender cover/protector local- per piece Ori 75.00 TW 45.00 Waja 1.6 Bumper Bracket- front local 95.00 TWWaja 1.6 front Bumper Original Proton Ori 160.00 TW 80.00 Waja 1.6 rear Bumper Original Proton- Ori 160.00 TW 80.00 Waja 1.6 rear sensor Original Proton 55.00 Kayaba absobers front (gas), rear (gas) per side F 135.00 70.00 Waja absorber mountings Original Proton local per side 80.00 Waja absorber link Original Proton per side 68.00 Waja Central Lock front per side, back per side Original Proton F 190.00 R 170.00 Waja window glass rubber per side 45.00 Waja Glove Box Handle 52Proton, rm26 localWaja Air-con Blower- please let me know Denso/ Patco--Waja Bosch wiperblade- 30.00 Waja H1 Osram-Waja 1.6 Bosch air filter Waja 1.6 bosch fuel filter Waja GMB water pump-Bosch Super 4 FR78X per box, Bosch Platinum Plus for 4 pcs,Bardahl oil treatment,1 can- Bosch Dot4 Brake Fluid 1 litre-Proton original ATF fluid 1 litre- per litreFuchs SP111 ATF fluild 1 litre-- German brandFuchs gear oil 80/90
ملحوظة الاسعار ده غير شاملة الشحن والجمرك يعنى ممكن اضافة 30%كمان
والاسعار برنمبت الماليزى يساوى حوالى 1.73جنيه مصرى
