بقالى 4 ساعات بنزله بعد كل الخطوات دى ...الجهاز اومنيا wm 6.5
Installation:
9. Install Folder 1: GarminMobileXTforWindowsMobile_42030w.exe (10.7 MB)
10. Make sure you choose STORAGE CARD AS TARGET.
11. See you PDA Prompted to install, Click YES.
12. After install, SOFT RESET
13. After boot up and enter windows. If Prompted to run the software, Select NO.
13. Now Connect to your activesync again, wait till the icon go green.
14. Instal Folder 2, BaseMap, install it, choose STORAGE CARD AS TARGET.
15. Instal Folder 3, Instal "Voice Support File". choose STORAGE CARD AS TARGET.
16. Now go to FILE MANAGER on your PDA, go to storage card you will find FOLDER: 2577
17. Delete That FOLDER.
18. Turn On your Bluetooth and make sure is allready paired and connected to your bluetooth devices.
19. for PDA with built in GPS no need to activate bluetooth.
20. Now go to program and find GARMIN XT Apps. Run the Apps.
21. Wait until Garmin XT screen appears with 4 selections to activate programs.
22. choose the bottom one (last one, the 4th), "use garmin bt devices"
23. select AGREE on the warning bla bla.
24. if there is prompt to search Bluetooth GPS device and ask you to go or stop. just click STOP (no need to search at this moment).
25. On the main screen see bottom and click "SETTINGS"
26. On the next screen see bottom right and click "DOWN ARROW"
27. You will see "ABOUT" click it.
28. You will see: "ESN ID" or "UNIT ID" or "CARD ID"
29. Write all of them in the piece of paper. double check it. don't miss one word.
30. click BACK and BACK again. and click EXIT.
Activation: (Now this is the fun Part!)
31. Go to Windows Explorer/My computer, on the top bar click TOOLS > Folder Options
32. Click TAB "File Types" and click "VIEW"
33. Scroll down a bit and UNCHECK "Hide extensions for known file types" then click OK to exit.
34. Now Open Folder 4. keygen_13_0.exe (Patched 1.3) this is not the same with regular JM 1.3 version.
(all credit of keygen goes to JETMOUSE).
32. Run the Keygen you will see 2 (two) entry field.
33. First entry field called "Enter your Unit ID here"
34. Now see your notes you wrote previously and enter your ID
35. For PDA using Bluetooth GPS receiver use "ESN ID" or "CARD ID"
36. For PDA using Internal Built in GPS (kaiser, D810, artemis) use "UNIT ID" or CARD ID"
37. Enter your ID and hit "Generate Button" you will get 25 Digit CODE.
38. select it double click it until highlighted (greyist) click RIGHT MOUSE AND COPY.
39. WARNING! DON'T CLOSE THE KEYGEN YET!! if you accidentally close it, start STEP 37 again.
39. Now go to Windows Explorer/My computer create a folder and open it.
40. inside that folder create .txt file by click RIGHT MOUSE>NEW>.... ........S
41. it will create "NEW .... .........TXT" (0KB)
42. open the file and click "PASTE", now your 25 code should be printed on the first line.
43. Save it. and close the .........
44. Now rename that file by right click on the file > Rename
45. Rename it like this: "sw.unl" make sure the .txt extension change to .unl
46. don't do this: "sw.unl.txt" (wrong!).
47. Now go to your File Manager at your PDA!!
48. make sure of this because there is Two Garmin FOlder inside your PDA. the one is at the internal memory/Root and the other one at storage card.
49. GO TO "STORAGE CARD" and find GARMIN FOLDER. put the file "sw.unl" there.
50. Now go to PDA and start GARMIN XT apps. it should take you to warning screen. and it won't ask you to activate the software again.
51. If not working and the Screen still locked and still seeing screen at step:21 above. you need to try different ID, maybe your card ID... maybe your ESN ID... try it see which one is work for you.
(WARNING!! DON'T ATTEMPT TO GO TO THE NEXT STEP WITHOUT SUCCESSFULLY COMPLETING THIS ONE FIRST)
52. if everything OK you should be happy 50% of your problem are gone.
....* NOW GO GET SOME BEER....*
53. let me remind you that the KEYGEN Still running.. don't close it yet.
MAP Activation: (This PART is the best part! My Favorite!)
54. Now download country map of your choice, map should be: "gmapsupp.img"
55. copy it to the GARMIN FOLDER at STORAGE CARD!
56. Now, Most map always acompany with file "MAPID.txt" it .......s MAP ID to that map.
57. but if you can't find the MAPID.txt, you can't find at Folder 6 (Collection MAPID) make sure you select the right one.
58. With the Keygen still open with your previously 25 code at the first field.
59. Now Go to SECOND FIELD called: "select Map Product"
60. Scroll down and go to the very bottom "CUSTOM MAPSET"
61. select it and enter the MAP ID and click OK.
62. It will gives you 25 CODE of MAP UNLOCK CODE.
63. select it by double click it and right click on the code then copy.
64. Again Repeat STEP: 39 by go to Windows Explorer/My computer go to previously created folder
65. Again inside that folder create .txt file by click RIGHT MOUSE>NEW>.... ........S
66. it will create "NEW .... .........TXT" (0KB)
67. open the file and click "PASTE", now your 25 code should be printed on the first line. SAVE and EXIT.
68. This Time Rename it like this: "gmapsupp.unl" make sure the .txt extension change to .unl
69. GO TO "STORAGE CARD" and find GARMIN FOLDER. put the file "gmapsupp.unl" there along with your country map (gmapsupp.img).
70A. Now, Run your GarminXT. if everything allright you should NOT get any ACTIVATION Screen whatsoever.
70B. You Can verify it by go inside GarminXT main Screen>TOOLS>Manage my Data>MAPSET>Detail Map.
71. You can start use your GarminXT 4.20.30! find Open Sky and start Navigating.
....* OK NOW DRINK YOUR BEER OR GET ANOTHER ONE ....*
Don't forget to help others in other forum who need help. don't be selfish.
TROUBLESHOOTING MAP UNLOCKING:
72. For unlucky people, if your map still not unlocked, check your MAPID make sure is the right one.
73. check your 25 UNLOCK CODE generate by Keygen, Try to avoid input 25 unlock code manually, try to use copy and paste instead.
74. check the name of the unl file.. makes sure "gmapsupp.unl"
75. make sure GarminXT is not running while you inserting the unl file.
76. are you sure you are following this step by step tutorial really step by step?? are you skipping some step?
77. make sure you are not CLOSE the keygen during STEP 39 ?? if you do You have to start from begining.
IMPROVEMENT: (OPTIONAL)
1. If everything OK.. if you want some improvement, You actually able to insert your CODE at gmapsupp.unl to your gmapsupp.img (MAP file) directly, it will be inside the map and integrated with the map without needing gmapsupp.unl file anymore.
2. simply googling free software called "gmaptool" and learn the command inside the HELP Files. its self explanatory.
3. the program is MS DOS Command. make sure you are familiar with DOS.
4. This Software able to EXTRACT the gmapsupp.img map file to be able visible to GARMIN MAPSOURCE. (it's Fun!)
وفشلت :(
بتظهرلى رساله
.Read access violation at data address 0x0000000. Program Address 0x006CF874 in thread GPX main."
هى الناس بتشغله على الاومنيا ازاى انا نفسى اعرف.....
