إختصارات الرموز الفنية للسيارات Abbreviation
كود:
Bodywork:
HBK: Hatchback
FBK: Fastback
LAN: Landaulette
TT: Targa top
SAL: Saloon (sedan)
FHC: Fixed-head coupé
DHC: Drop-head coupé (cabriolet; convertible)
TOUR: Tourer
RDSR: Roadster
EST: Estate (station wagon; shooting brake)
MPV: Multi-purpose vehicle
LDV: Light delivery vehicle
VAN: Van (panelvan)
SUV: Sport-utility vehicle
ORV: Off-road vehicle
LIM: Limousine (limo)
ESP: Electronic Stability Program
كود:
Valve gear:
OHV: Overhead valves
SOHC: Single overhead camshaft
DOHC: Double overhead camshaft (per bank)
SV: Side valves
SL: Sleeve valves
TS: Two stroke
ROT: Wankel Rotary
oise: Overhead inlet, side exhaust
RV: Rotary valves
كود:
Chassis:
FWD: Front wheel drive
RWD: Rear wheel drive
AWD: All wheel drive
4WD: Four wheel drive
كود:
Fuel system:
Ai: Aisan
Am: Amal
Au: Autolite
B&B: Ball & Ball
Bi: Bing
Ca: Carter
De: Dell'Orto
Fo: Ford
Hi: Hitachi
Ho: Holley
Ji: Jikov
Ke: Keihin
Lu: Lucas
Mi-So: Mikuni-Solex
Mi: Mikuni
Ni-St: Nikki-Stromberg
Ni: Nikki
R-R: Rolls-Royce
Ro: Rochester
Ru: Russian
SU: SU
So: Solex
St: Stromberg
We: Weber
Ze: Zenith
FI: Fuel Injection
EFI: Electronic Fuel Injection
SMPFI: Sequential Multi-Point Fuel Injection
SFI: Sequential Fuel Injection
MPFI: Multi-Point Fuel Injection
DDI: Direct Diesel Injection
GDI: Gasoline Direct Injection
Ku: Kugelfischer
Ku-Bo: Kugelfischer-Bosch
Lu-Bo: Lucas-Bosch
Ho PGMFi: Honda programmable fuel injection
Ma-We: Marelli-Weber
Ni-De: Nippon-Denso
كود:
Suspension:
ARB: Anti-roll bar
CS: Coil springs
dD: de Dion axle
DW: Double wishbones
I: Independent
LA: Live axle
LowTrailLi: Lower trailing link
LS: Leaf spring
LW: Lower wishbone
MS: Macpherson strut
MultiLi: Multi-link
PR: Panhard rod
QE: Quarter-elliptic leaf springs
RA: Radius arms
SE: Semi-elliptic leaf springs
STA: Semi-trailing arm
STLi: Semi-trailing link
SlPl: Sliding pillar
SwAx: Swinging axle
TA: Trailing arm
TB: Torsion bar
TL: Transverse leaf spring
TrailLi: Trailing link
TzLi: Trapezoidal link
U&LW: Upper & lower wishbones
U&LRA: Upper & lower radius arms
UW: Upper wishbone
W: Wishbone
WL: Watt's linkage
كود:
Brakes:
Ve: Ventilated
Di: Disc (Disk)
Dr: Drum
S: Servo-assisted
ABS: Anti-lock Braking System
EBD: Electronic Brake Distribution
كود:
Transmission:
A: Automatic
M: Manual
SA: semi-automatic
WP: Wilson preselector
CVT: Continuously variable transmission
OD: Overdrive
2X: Dual Speed Transfer Box
SM: Sequential Manual
M-CVT: Manual function-Continuously Variable Transmission
S: Sequential
P: Preselect
