ربنا يسهلك بيعها
رقم العضوية : 72606
الاقامة : Suez
السيارة: Suzuki Maruti
السيارة[2]: Daewoo Lanos
←اسم الجهاز / كاميرا فيديو
← الموديل / ياباني PANASONIC NV-VZ 1 PAL S-VHS-C Camcorder
← المتعلقات / الكرتونة ووصلة للتوصيل لكرت فيديو أو كرت تحرير الفيديو والريموت كنترول
←حالة الجهاز / استعمال خفيف جدا
← السعر / 750 جنية
← سبب البيع / عدم الاحتياج
صورة الكاميرا
المواصفات
- 20X Optical Zoom & 480X Digital Zoom
- 2.5-inch Smart-Turn Colour LCD
- Super-VHS recording & Super-VHS ET recording
- Easy Menu Operation
- Digital Interface Terminal allows any still picture you choose to be uploaded to a PC
- Best price at welectronics.com
- 0-Lux Night View records under conditions too dark for the human eye, thanks to infrared rays emitted from the camera
- Motion Sensor function automatically starts recording when movement is detected and can be used in conjunction with the Night View function
- Super Image Stabiliser prevents image distortion due to camera shaking
- Digital Superimposer creates titles and illustrations and superimposes them onto your recordings during REC and PLAY modes. This does not impair the original image and requires no extra equipment
- 16-Digital Effects can be added during REC mode and 12- in PLAY mode for creative flexibility
- Negative / Sepia / Solarization / Black & White / 3 x Fade Options / Mosaic / Stretch / Multi-Screen / Picture-in-Picture / Mirror / Mix / Wipe / Strobe / Gain-Up
- 8-Colour Titles for frequently used titles stored in a choice of eight different colours and either large or small in both REC and PLAY modes
- Digital TBC (Time Corrector) helps assure stability by preventing vertical distortion caused by timing irregularities (called 'jitter')
- Voice Zoom function allows you to make far away sounds easy to hear by bringing them closer
- Multi-Screen allows you to either call up a chronological sequence of nine still frames on the screen one after another or divide the screen into nine sections and view them all at once
- Picture-in-Picture allows you to display an inset image within the main screen
- Digital Noise Reduction controls noise reduction level in line with signal input strength during REC mode and removes image signal interference during PLAY mode for natural, stable images with straight vertical contours
- Long-run Lithium-ion Battery
- Infra-red Remote Control
- Video Format Super-VHS-C
- CCD Image Sensor 1/5"
- CCD Capacity (pixels) 450k
- Lens F1.6
- Long Run Lithium-ion Battery
- Smart-Turn Colour LCD 2.5"
- SP/LP recording & playback
- Optical Zoom 20X
- Digital Zoom 480X
- Programme A.E. (Auto Exposure) 7-mode
- 0-Lux Night View
- Motion Sensor
- Digital Superimposer REC and PLAY Modes
- Digital TBC
- Voice Zoom
- Multi-Screen / Picture-in-Picture
- Digital Effects 16-mode:
- 12-REC and PLAY Effects Negative / Solarization / Sepia / Black & White / 3 x Fade / Mosaic / Stretch / Picture-in-Picture / Mirror / Strobe
- 4-REC Only Effects Multi Screen / Mix / Wipe / Gain-up
- Focus/ White Balance/ Fade
- P.C. Interface
والموقع ده فيه كل التفاصيل عن الكاميرا وسعرها جديدة بالدولار
http://www.220-electronics.com/camco...sonicnvvs5.htm
رقم العضوية : 8099
السيارة: ربنا يكرم
السيارة[2]: FRV 2009
ربنا يسهلك بيعها
meshmesh78 سابقا
رقم العضوية : 72606
الاقامة : Suez
رقم العضوية : 72585
السيارة: 00000
السيارة[2]: fiat 132
دراجة بخارية: -----------------
السعر النهائي من فضلك ورقم تليفونك علي الخاص
رقم العضوية : 72606
الاقامة : Suez
النهائى 600
الموبايل 0102243457
سبحان الله وبحمده .. سبحان الله العظيم
رقم العضوية : 72585
السيارة: 00000
حلتها ايه
بطارية
شكل
جروح في شكها
العدسة
كدا يعني
رقم العضوية : 8099
السيارة: ربنا يكرم
لو سمحت هى دى بتشتغل بكروت ميمورى ام شرائط فيديو
ولو بكارت كرتها كام؟
وشكرا
meshmesh78 سابقا
رقم العضوية : 72606
الاقامة : Suez
البطارية بتشتغل لساعة ونص
والعدسة سليمة من غير اى خدش لانها دايما كانت مقفولة فى علبتها
ومفيش خدوش او جروح فيها وحالة الكاميرا تمام وشغالة زى الفل
لا هيا مش بميمورى وبتشتغل بالشرايطلو سمحت هى دى بتشتغل بكروت ميمورى ام شرائط فيديو
وشكرا
رقم العضوية : 277
الاقامة : Alex
السيارة: -uno-swift93
السيارة[2]: auto bianki men zaman
سعر مناسب
ربنا يوفق
حريتك تنتهي ..حين تبدأ حرية الأخرين
