الاولانى زى بتاعى اسمه GTO 6000
التانى الاسود اسمه
JBL GTO 755.6 هو موجود فى التوكيل مشغلينه فى ستاند العرض وكل لما اسأل يقولولى منعرفش سعره بس هو فى حدود 3000 جنيه
الاتنين 6 تشانل
Product Description
Power Output: 60 watts RMS x 4 channels + 107 watts RMS x 2 channels at 4 ohms and ≤ 1% THD
RMS Power into 3 channels: 160 watts x 2 + 300 watts x 1 at 4 ohms, 14.4V supply and ≤ 1% THD
MAX Power: 4 x 120W max + 2 x 200max (or 4x120W + 500W max)
Signal-to-Noise Ratio: 79 dBA (reference 1 watt into 4 ohms)
Dynamic Power: 117 watts (channels 1,2,3,4); 163 watts (channels 5,6)
Effective Damping Factor: 6.392 at 4 ohms
Frequency Response (?3dB): 10Hz - 47kHz (channels 1,2,3,4); 10Hz - 302Hz (channels 5,6)
Maximum Input Signal: 6V
Maximum Sensitivity: 250mV
Output Regulation: .042 dB at 4 ohms
Dimensions (W x H X D)
Main Unit: 2-3/8" x 18-11/16" x 12-5/16"
