أنا مش مصدق أغلب اللي مكتوب في الموقع ده لان موقع إعلاني لجهاز غريب زي إعلانات التلفيزين كده اللي كلها نصب
الأيونات السالبه مش بتزيد الذكاء و لا بتحافظ على الصحه و لا بتحسن المزاج
هموت و أعرف مين دكتور كورنبول ده
الموضوع غير مثبت علميا خالص و مش مجال بحث واسع
من الآخر خالص تأيين الهواء بينقي الجو بس بينتج غاز الأوزون اللي لازم تركيزه في الجو ما يزيدش عن 5/100 جزء من المليون
Mr. Static
اقتباس:
None of the experiments showed any significant deviations from the normal ion-concentration values. Note that there probably is such a thing as a sick building, but it apparently has nothing to do with atmospheric ions.
اقتباس:
this myth is taken as another proof that positive ions are harmful because they attach themselves to pollutants. If this really were the case, it would mean that polluted air would have an excess of negative ions, as the pollutants would swallow positive ions. However, as already stated, this is not so. Polluted air may have low concentrations of both positive and negative ions.
Some Air Purifiers Create Smog-Like Conditions | LiveScience
Nizkorodov and colleagues tested various air purifiers in homes, offices and cars. In many cases, according to a statement, ozone levels inside climbed above 90 parts per billion, exceeding California's basic safety threshold. In some cases, ozone soared higher than 350 parts per billion, which if measured outside would trigger a Stage 2 Smog ....., an event that hasn't occurred in the Southern California coastal air basin since 1988.
