no, it is not toxic or the degree of toxicity is very low . the problem lies on the fact thatthe freon gas contains chlorine and bromine atoms which in a certain mechanism are transferred into radicals causing the demolishing of ozone laye . but certainely it isnt toxic because,the same compunds forming the freon gas called CFA(chlorofluror carbons) are used as propellent in some inhalers :D, they wont be used in inhalers if they were toxic, right???
you can use the wikipedia to get sure :D
