It is a good opportunity that you are on line,i wonder if you could help me about that silly problem i am having now.the car is not running well as if it is suffocating especially with the AC on.It stars shortly after turning the AC on
Thanx
Thanx
ما ينفعش نكتب بالعربى علشان الكل يستفاد
على العموم شيك على طرمبة البنزين والرشاشات والبوبينة علشان العربية تشتغل
the car is running very well
check the fuel pump pressure and spark strength
make sure you don't have any vacuum leaks or intake restrictions
if you do have your CEL on then get her scanned
change your elect sparks and replace it
check the gazolin filter
thank you very much
:P
لا اله الا الله
محمد رسول الله
disconnect the feed line from the fuel filter then turn the ignition key to ON... their should be a strong rush of fuel coming out of the fuel line
also with the A/C off... low fuel pressure will cause hesitation when you floor the pedal on low speeds... try that and see what happens
for the spark strength you gotta remove the spark plug cables from the coil pack with engine running but keep it within 2 cm from the coil ports to allow the spark to jump from the coil pack to the cable... if the spark is too weak to jump the gap then it is a coil problem
also when you are doing 30KPH shift to third gear and floor it... if the car sputters then it is a spark plug cables issue
does this mean that the CEL comes on when you turn on the A/C and the hesitation occurs?اقتباس:
.the CEL is not on, it only occurs when the AC on
and this doesn't happen if the A/C is not on... right?
and does this occur when you start stepping on the gas pedal or during acceleration in general?
