يعني من الاخر يا رامي باشا
ايه احسن نوع بوجيهات ممكن اركبه للجين 2 2008 واجيبه منين ؟ وبكام؟ والكود ده اعرفه منين؟
خالص تحياتي
استاذ رامى الرجاء معرفة ان BKR6EIX 6418 NGK غير متوافقه مع الجين 2 تماما و تؤثر على ماتور الجين 2 وده رأى توكيل NGK انا بعتلهم مايل :
Dear Ahmed,
As we are the UK based offices of NGK Spark Plugs, we can only offer
comment on UK vehicles. The plugs used in other countries may well differ
from parts that are available here in the UK.
BKR6EIX is NOT compatible with your Proton Gen 2 as it has the incorrect
seating method required for your cylinder head design.
The UK models use a taper seat plug, not the gasket seat plug you have
quoted.
The plug that you removed from your vehicle will most likely be an NGK
item as original equipment, part number BPR6EFS-11. If you check the plugs
fitted to your vehicle and it is indeed a BPR6EFS-11, then BPR6EFIX-10 can
be used as an Iridium upgrade for the this part number.
Thank you for your enquiry.
Regards,
Mik Peirce AffIMI
Technical Assistant
NGK Spark Plugs (UK) Limited
Maylands Avenue
Hemel Hempstead
Hertfordshire
HP2 4SD
Tel: 01442 281000
Fax: 01442 281001
Website: www.ngkntk.co.uk
Site contact email
ahmed_elsalamony
to:
techweb
24/08/2010 08:38
Message: Hi, i have Proton Gen 2 Campro 1.6 A/T Model 2008 and i want to
know if NGK Spark Plug with part number: BKR6EIX is compatible with Gen 2
without any bad side effect or not. many thanks any advance. Regards Ahmed
Reda
NGK Spark Plugs (UK) Limited is a limited company registered in England and Wales.
Registered number 1212088. Registered office: 35 Vine Street,London, EC3N 2AA
This e-mail message has been scanned for Viruses and ....... and cleared by MailMarshal
رأى توكيل بروتون:
Dear Mr. Reda
thank you for your recent e-mail, the correct spark plug for your vehicle is NGK BPR6EF-11 this make and type of plug has been researched and is known to deliver the correct results and performance for your engine at the best possible price, all the ignition components are matched therefore I can only advise you to use the original specification plug as I can see little or no benefit of moving to a Iridium plug.
I hope this information is of use to you
Peter Clifford Eng Tech M.I.M.I
Proton Technical
Proton Cars (UK) Ltd
Units 1-3 Crowley Way
Avonmouth
Bristol BS11 9YR
DD: +44(0) 1179 386378
Fax: 01179 380614
Email: Peter.clifford@proton.co.uk
Registered Office: 1-3 Crowley Way, Avonmouth, Bristol, BS11 9YR
Registered in England No: 1857505
VAT Registration No: 584 9800 94
Content Relevant URLs by
vBSEO 3.6.0 PL2
