Next BMW 1-Series will get new engines
http://pictures.topspeed.com/IMG/cro...i-1_460x0w.jpg Patiently waiting for the next generation BMW 1-Series to debut, we know we probably won’t be seeing it over on this side of the pond. However, that won’t stop us from taking notice of the interesting changes the BMW will undergo. The first, and most obvious changes, will appear on the exterior of the vehicle. Well, we probably shouldn’t say "most obvious" considering the redesigned bodystyle is anything, but extravagant. The biggest changes will be made under the hood as BMW will be offering a wide range of engines, including turbo-petrol engines with three or four cylinders. However, the BMW 1-Series will remain a RWD vehicle built on the same L7 platform as the 3-Series. The entry level models will get 1.2 and 1.5 liter engines with power outputs ranging from 70 to 184 HP. Next to it there will be a 2.0-liter four-cylinder engine with 204 HP and 238 HP and a range of three-cylinder engines with outputs ranging from 95 to 177 HP. The top version will still get the six-cylinder N55 Twin-Scroll engine. The first hatchback version will be revealed in early 2011, and it will be followed by both coupe and convertible versions
