رقم العضوية : 13687
الاقامة : Cairo - Doha
السيارة: Optra 2008 A/T
السيارة[2]: Kia Cerato K3 TopLine
دراجة بخارية: -
Patiently waiting for the next generation BMW 1-Series to debut, we know we probably won’t be seeing it over on this side of the pond. However, that won’t stop us from taking notice of the interesting changes the BMW will undergo.
The first, and most obvious changes, will appear on the exterior of the vehicle. Well, we probably shouldn’t say "most obvious" considering the redesigned bodystyle is anything, but extravagant. The biggest changes will be made under the hood as BMW will be offering a wide range of engines, including turbo-petrol engines with three or four cylinders. However, the BMW 1-Series will remain a RWD vehicle built on the same L7 platform as the 3-Series.
The entry level models will get 1.2 and 1.5 liter engines with power outputs ranging from 70 to 184 HP. Next to it there will be a 2.0-liter four-cylinder engine with 204 HP and 238 HP and a range of three-cylinder engines with outputs ranging from 95 to 177 HP. The top version will still get the six-cylinder N55 Twin-Scroll engine.
The first hatchback version will be revealed in early 2011, and it will be followed by both coupe and convertible versions
[aldl]http://s17.postimg.org/ygne2hebj/F2000045710.jpg[/aldl]
رقم العضوية : 23065
الاقامة : Egyptian highways
السيارة: -------
السيارة[2]: Hyundai Verna 2007
thanks Hossam, here's more :)
BMW releases second 1 Series M Coupe teaser
by Damon Lavrinc (RSS feed) on Aug 27th 2010 at 7:57PM
BMW 1 Series M Coupe – Click above to view the video after the jump
The achingly slow striptease of the BMW 1 Series M Coupe continues with a 47-second-long spot of the camo-clad coupe bearing just enough sheet....l to keep us interested.
The multi-spoke wheels, drilled discs and quad-exhausts are the only elements not left to the imagination, but the extra vinyl aft of the front wheels is sure to hiding a set of M-style fender vents while a ducktail spoiler is fitted out back.
As for mechanicals, the smart money is still on an upgraded twin-turbocharged inline-six (N54), channeling over 335 horsepower through a manual gearbox and down to the rear wheels via a torque-vectoring M differential.
We're hearing rumblings that the Coupe could be unveiled at next week's Oktoberfest BMWCCA event in Wisconsin, but in the meantime, check out the latest teaser after the jump and scope the first vid in our previous post. Thanks to everyone for the tips!
YouTube - BMW 1 Series M Coupأ©. Unveiled.
