Model Classifications, Dimensions And Weights
Model, Code and Production Year - CBR400RR-J (1988)
Frame Numbers - NC23-1020001 to 1036454
Engine Numbers - NC23E-1020001 to 1036510
Carburettor Number - VG04A
Wheelbase - 1370mm
Overall length - 2020mm
Overall width - 690mm
Overall height - 1110mm
Ground clearance - 120mm
Weight (dry) - 179kg
Model, Code and Production Year - CBR400RR-K (1989)
Frame Numbers - NC23-1090001 to 1098116
Engine Numbers - NC23E-1090001 to 1098123
Carburettor Number - VG04B
Wheelbase - 1380mm
Overall length - 2202mm
Overall width - 675mm
Weight (dry) - 182kg
Model, Code and Production Year - CBR400RR-L (1990 and 1991)
Frame Numbers - NC29-1000001 to 1010598
Engine Numbers - NC23E-1300001 to 1310636
Carburettor Number - VP01A
Wheelbase - 1365mm
Overall length - 1990mm
Overall width - 670mm
Overall height - 1080mm
Ground clearance - 125mm
Weight (dry) - 180kg
Model, Code and Production Year - CBR400RR-N (1992 and 1993)
Frame numbers - NC29-1050001 on
Engine Numbers - NC23E-1420001 on
Wheelbase - 1365mm
Model, Code and Production Year - CBR400RR-R (1994 - on)
Frame Numbers - NC29-1100001 on
Engine Numbers - NC23E-1500001 on
Carburettor Number - VP01B
Wheelbase - 1365mm
Ground clearance 125mm
Specifications CBR400RR-N
Type Four-stroke, dohc, in-line four cylinder
Capacity 399cc
Bore & Stroke 55.0mm x 42mm
Compression Ratio 11.3:1
Valve Train Gear Driven DOHC; 4 valves per cylinder
Cooling System - Liquid cooled, radiator with cooling fan
Clutch - Wet multi plate
Clutch operation - Cable operated
Transmission - 6-speed
Primary reduction - 2.117 : 1 (72/34)
Final reduction (sprockets) 2.600 : 1 (39/15)
Transmission - 6 speed constant mesh
Final drive chain - 102 links, split
Frame Twin spar, box-section aluminium
Front Suspension - Oil-damped telescopic forks
Rear Suspension - Single shock absorber with 3-way linkage
Front brakes - Double floating disc; 2-piston Nissin sliding callipers
Rear brake - Single solid disc; single-piston Nissin sliding calliper
Fuel tank capacity - 15.0 liters (4.0 U.S. gal., 3.5 Imp gal.)
Ignition system - Digitalized full transistor ignition
Starting system - Electric
Battery Type - YTX7L-BS
Charging system - Triple phase output alternator
Regulator/rectifier type - SCR Shorted/triple phase full wave rectification
Recommended engine oil -SAE 10W-40
Engine oil capacity at oil filter change - 3.4 litres
Idle speed - 1,300 +/- 100 rpm
Cold tire pressure (driver only, front) - 33 psi (2.25 bar)
Cold tire pressure (driver only, rear) - 33 psi (2.25 bar)
Cold tire pressure (driver & pass., front) - 33 psi (2.25 bar)
Cold tire pressure (driver & pass., rear) - 36 psi (2.50 bar)
Spark plug (standard) - NGK CR8EH-9 or equivalent
Spark plug (racing) - NGK CR9EH-9 or equivalent
Spark plug gap - 0.8-0.9mm
انتا بقي تشوف رقم الشاسيه مابين انه ارقام في دووول علشان تتأكد و علي العموم لو فير حتبقي فوق موديل 90 لكن لو عادة حتبقي 88 او 89
و اي حاجة احنا معاك:10D5C8w1107::10D5C8w1107:
