السلام عليكم ,
وجدت موضوع عن السماعات فى اللوجان و احجامها و كيفية التعدل و هذا هو النص :
Mahindra Logan:
Front door: 5.25”
Rear door:5.25”
Whats possible:
-front doors can take 5.25” components easily and 6.5” components with a MDF spacer ring. The tweeters can be mount near the internal door release or on the ORVM pod trims for best effects.
-rear doors don’t have stock speaker locations and are best left free.
-rear parcel tray takes 5.25” stock and 6.5” speakers with a bit of mods and its best to avoid cutting the rear parcel tray to install bigger(6x9)speakers as it forms a structural component of the car.
-free air subs can be mounted on the rear parcel tray but this again needs ....l cutting and should be avoided the better option to have would be a ported enclosure in the boot.
-be vary of doing a lot of trim modifications are the swift is inherently a ‘rattle snake’!
-amps/3-way component/multi-sub setups with accessory batteries etc can all go inside the car
الترجمة فى الرد القادم
