thanks for that
رقم العضوية : 30094
الاقامة : EgYpTo
السيارة: Only One
السيارة[2]: Private
دراجة بخارية: RR
Hyundai cars are designed to be driven in all areas of the world, by people of all ages and levels of experience and sophistication. They are set to operate at all altitudes and temperatures and to use fuels of varying octane-rating and purity.
Unsurprisingly, the electronic engine control unit of your vehicle has been pre-set to a `one-size-fits-all` state of tune. Whilst the ECU has the capacity to adapt to the owners driving-style to a certain degree, the base-settings are extremely conservative and Hyundai's are famously set to run rich!
Most owners would naturally suppose that this situation is something over which they have no control, this is not the case.
This ........ will instruct any owner on how to change the ECU settings of their car, without the alterations being detectable by the Dealership, the Insurance Company, or indeed having any effect on the vehicle's warranty.
The operations described are recommended as a first step after taking over ownership of the car, after carrying out any performance modifications, or after any temporary change in the way the vehicle has been used ( i.e. city-bound use, towing etc.).
Firstly bring the car to normal operating temperature by driving for 15 minutes or so.
Now open the bonnet and disconnect the earth lead from the battery, ensure this is not touching any part of the bodywork - insulate if necessary - and wait 5 minutes.
Next depress the foot brake for 20 seconds - this will completely discharge the ECU's capacitors via the brake lights.
The next step (to be carried out immediately, while the engine is still warmed-up) is to carefully re-connect the battery earth lead, close the bonnet and now drive the car in a spirited fashion (accelerating rapidly through the gears, full-throttle straights etc. etc.) for a full 30 minutes. Try to choose a quiet time on the roads for this, (i.e. early on a Sunday morning!).
This period of driving will `re-educate` your ECU into adopting more aggressive timing curves and alter the fuelling to match. It will also allow the unit to recognise any modifications you have made and to react accordingly.
If, on the other hand, you are not interested in outright performance, but are more concerned with economy and flexibility, use your normal driving style during this 30-minute run!.
Over time, the ECU will slowly revert to the factory settings......especially if it is not being driven `spiritedly` on a regular basis.
Accordingly, many owners tend to do this reset monthly, or before a track day or even a long run.
[glow1=#7a3131]Dr.Ahmed AlSherif[/glow1]
رقم العضوية : 28833
السيارة: Mitsubishi Pajero 2010
السيارة[2]: Hyundai Verna 2009
دراجة بخارية: Keine
thanks for that
رقم العضوية : 81462
السيارة: kia
السيارة[2]: fiat
يا جماعه ايه الكلام دة كله واحدة واحدة الموضوع مش مستاهل كده خالص دة ابس ما تتخيلو باذان الله انا اول ما جيبت العربيه و كانت عامله 250 كيلو كنت جايب بيها 190 وبعد 15000 كده قولت اشوف ايه حالتها لاقيت نفس الموضوع ده مش عايزة تعدى ال 170 بس بعد كده عرفت ازاى اعديها انت لو عايز تعدى السرعه دى اعمل الى هقولك عليه و دة من الاخر باذن الله هات الفتيس على الستيبترونيك وهى هتجيب معاك ال200 لو عايز جرب وادعيلى
رقم العضوية : 80173
الاقامة : nasrcity
السيارة: nubira
السيارة[2]: nubira
العربية لسه محتاجة تفتيح اهدا و متحملش على العربية في الاول و لما تتفتح حتلاقيها فارئت. و ربنا يستر طاريقك و بلاش السرعات العالية.
رقم العضوية : 20585
الاقامة : 7dayek al ahram
السيارة: none
السيارة[2]: KIA New Cerato EX 2010
دراجة بخارية: None
رقم العضوية : 28833
دراجة بخارية: Keine
رقم العضوية : 8428
الاقامة : Alexandria/Cairo
السيارة: None
السيارة[2]: Kia Cerato SX
طب أنا موضوع التفتيح د عملتو نوعاً ما على أول تلت نقلات و الحمد لله مفيش أي شكوى منهم.. بس المشكلة فالرابع.. أول مل عربية بتجيب الرابع بتتحول.. بطة بلدي رسمي.. و حاولت عل صحراوي كذا مرة افتحو بس مفيش إستجابة أوي.. العربية بتجيب 180 و خلاص كدا، و لو في منزل أو حاجة بتجيب 190 بالعفية.. انما 190 بنص الدواسة دي صعبة شوية
shadowdancer851 سابقا
