فى حد اكد لحضرتك ان دى اللى حتنزل مصر كمان شهر ؟؟؟
مبروك مقدما
رقم العضوية : 24673
السيارة: .....
السيارة[2]: Grande Punto 2009
الساجا 2011 هتبقى غير 2010 تماما والحمد لله ان الواحد استنى وربنا يكرم وتنزل مصر 2011 كمان شهر إن شاء الله
وان شاء الله تنزل مصر ومتبقاش 2010
اسيبكم مع الصور والتغيرات الى حصلت فى العربيه
We’re here at the Thai Motor Expo 2010 for some pre-KLIMS motorshow action, where Proton has unveiled the 2011 Proton Saga facelift! Here’s an initial list of changes from what we’re able to tell so far:
The entire front end has pretty much changed from the head lamps, grille, bumper, and even the engine hood sheet ....l design. The new engine hood now creases in a way that makes the left and right sides of the hood higher. There’s also a very faint spine in the middle of the hood, where in the pre-facelift Saga it was flat.
The headlamps now appear to use three bulbs instead of the previous two bulb config – we think this means there’s a dedicated bulb for high beam now. The signal lamps have been moved towards the inside of the lamps.
The wing mirrors now have turn signal indicators.
The rear end also has significant changes. The tail lamps are new and have LED lighting. There’s a small spoiler on the boot lid, and because of the spoiler design the Saga badge has to be relocated slightly to the left.
The bumper now has a black insert for the diffuser-like design feature, and it’s now wider with reflector lenses and shaped to show off the exhaust muffler and tail pipe, as opposed to the pre-FL Saga which had its rear end designed to hide the exhaust tail pipe.
The 1-DIN Clarion radio looks the same to us (except for the MP3/WMA logos which indicate support for those files), but there are new USB and AUX-in ports which are not integrated into the radio but are instead positioned to the lower right of the radio. This takes up some of the cubby hole space below the radio.
The steering wheel now has audio control buttons, similiar in style to the Satria Neo’s.
The fabric pattern on the door cards and the seats are now of a different design (old one is on the left). The baseline model in Thailand has a yet another different fabric pattern, and the one we are showing above in comparison to the old fabric is the high spec fabric pattern.
There are now rear power window button controls. As for which of the Malaysian car specs will feature rear power windows and which won’t, we’ll have to wait for the Malaysian launch.
There’s a new alloy wheel design, but the tyre size is the same as before – 185/60R14.
There’s now the option for a front passenger airbag which takes up the ’tissue box’ holder compartment in the pre-facelift Saga.
These are the only changes we are able to see so far, and we have to note that some of these updates like the USB/AUX function, the extra airbag and the rear power windows could only be for the higher spec models. Four colours are available in Thailand – Solid White, Tranquility Black, Genetic Silver and the new colour you see here which is Blue Rock.
There could be other changes on the mechanical side of things though, which we will probably only be able to find out when we speak to Proton’s engineers in Malaysia. The Thai spec sheet (which you will be able to see after the jump) quotes 70kW and 120Nm, which is the same as the pre-facelift Saga.
Enjoy a high-res product and live image gallery as well as a video after the jump.
IPhone 6 Black 16GB Sealed for sale
http://www.nilemotors.net/Nile/451878-iphone-6-black-16gb-sealed-sale.html#post3875842394
رقم العضوية : 65980
الاقامة : 6 اكتوبر والزقازيق
السيارة: corolla 2008 high line
السيارة[2]: proton gen 2
دراجة بخارية: لايوجد
مبروك مقدما
[sor2]http://img534.imageshack.us/img534/7595/resize63.jpg[/sor2]
رقم العضوية : 24673
السيارة: .....
رقم العضوية : 47170
الاقامة : مصر
السيارة: Gen 2 - 2011
السيارة[2]: بيجو 505 + Citreon Xsara
رقم العضوية : 2989
الاقامة : حلوان
السيارة: كفاية واحدة
السيارة[2]: Lancer 2006
أنا قرأت في أماكن تانية عن العربية دي وعرفت إنها مصممة خصيصا للسوق البريطاني
واتمنى إنها تنزل مصر طبعا وأنا أساسا مستني الدفعة اللي جاية من الساجا الاوتوماتيك سواء 2010 أو 2011
وفي التوكيل قالولي إنها هاتغلى 4000 جنيه مش عارف ليه وما حددش أي واحدة فيهم
رقم العضوية : 77301
الاقامة : الهرم
السيارة: هوندا اكورد 1989
السيارة[2]: بروتون ساجا 2010 A\T
متقدش ان ديه هتنزل مصر دلوقتي لأن الساجا لسه نازله مصر و مستحيل ينزلوا شكل تاني ليها علي طول كدا بس هيه عربيه تحفه بصراحه
Protony 4 EverI Love Sagaلو لم اكن بروتونيا لوددت ان اكون بروتونيا
رقم العضوية : 69176
السيارة: .Lancer EX 2008 F\O A\T
السيارة[2]: Proton Saga 2010 A\T
الساجا يا استاذ احمد هيا هيا موديل 2010 هوة هوة 2011 من غير تعديلات نهائيا .... وده من كلام ناس كتير في التوكيل منهم استاذ نذير اللي اكدلي المعلومة دي ...
[rmade]http://i94.photobucket.com/albums/l108/sayed911/alex-1.jpg[/rmade]
To Follow me on Twitter "Sayed_K_H
رقم العضوية : 24673
السيارة: .....
رقم العضوية : 80712
الاقامة : beni seuf
السيارة: .........
السيارة[2]: هيونداي لافيتا ........
اتمني ان اشء الله ان تنزل مصر الشكل الجديد
رقم العضوية : 46867
الاقامة : المهندسين
السيارة: ــــ
السيارة[2]: Gen 2 - 2010
دراجة بخارية: ــــ
الشكل الجديد تحفة بس انا اعتقد انها لو نزلت مصر هايكون تمنها أغلى حوالى 8 الاف جم ع الاقل عن الساجا 2010
