ممكن تشوف الموضوع ده هايفيدك:
http://www.nilemotors.net/Nile/showthread.php?t=51161
جااااااااااامد موضوع العداد ده ...
احنا عندنا ال A5 تكييف تتش هبقى اجرب و اقولكو .....
wawwwwww
انا جربته امبارح فى عربيتى A4 جامد موت
بس مش بيدى السرعه الحقيقيه بيتأخر ب 10
يعنى كنت ماشى 100 والعداد الديجيتال 90
بس انا نفسى اعرف بقية ال options
دول 60 رقم وكل رقم بدى قراءة مختلفه
اعرف من اين باقى الرقام دة تدل على ايه
متشكرين جدا لصاحب الفكرة
:biggrin2::biggrin2:
Here is the rest of options :
00 = total placing value, 0=max. cool, 255 max. heat
01 = interior temperature sensors (at the operating sector of the Climatronic)
02 = average sun exposure index
03 = sun exposure index in mW/cm²
04 = outside temperature bumper (averaged)
05 = current value: Outside temperature bumper
06 = temperature fresh air suction port (?)
07 = temperature Fussaustroemer
08 = temperature, but no feeler attached
09 = blower regulation (one can with +/- blower engine regulate)
10 = blower strength
11 = temperature flap (0 = max. warmly, 255 = max. coldly), (+/)
12 = flap torso (+/)
13 = flap circulating air (+/)
14 = flap for windshield (+/)
15 = time since engine start in seconds of
16 = speed (Digitaltacho)
17 =?
18 = mostly is 0. Sporadically I had there 65, 68 and 69 (wenn's very, very hot). No idea, which means it.
19 =?
20 =?
21 =?
22 =?
23 =? Temperature identification with #7?!
24 = act. Temperature heat flap od.: one over +/- adjustable temperature. I take to it am the maximally permitted temperature for NR. 23 and/or NR. 7, thereby the feet does not anbrennen
25 =?
26 = actual value of temperature flap
27 =?
28 =?
29 = actual value floor space?
30 =?
31 =?
32 = actual value of circulating air flap
33 =?
34 =?
35 = actual value of window nozzle (Defroster nozzle or as **** yourself calls)
36 =?
37 =?
starting from 38 stand firm worth:
38 = 10
39 = 0
40 = -51°C
41 = 0
42 = 3
43 = 2
44 = 0
شكرا لصاحب الموضوع على الطرح
وده بيفكّرني بأرقام النوكيا :)
انا اسف يا باشا على التاخير بس اصلى بعيد عنكو عيااااااااااان و مرمى فى البيت من امبارح :_Alshmokh08[1]: ان شاء الله اول لما اخف هجربها بس انا عندى استفسار ...
فى ال A5 فى بكرتين لظبط الحراره عشلن كل جمب فى العربيه بتظبط حرارته لوحده ....
يا ترى بقى اعمل واحده منهم بس و لا اعمل ال 2فى نفس الوقت ؟؟؟؟؟
