re-coding your car keys
for unknown reasons the car keys may loose the code to open or close the center lock also u are unable to trigger the alarm.
symptoms: The center lock & alarm are not responding to your remote control key also not responding to your spare key while u r sure that both keys are working fine and batteries are fine.
solution: Get both the original and spare key and follow these steps carefully
1- put the key in the ignition
2- push the alarm button with your left hand and don't release the alarm button (round button with a small dot located in the dashboard)
3-turn on the key to position 1 (the engine lamp and all other lamp will turn on )
4- count 5 seconds then turn the key to position 0 and remove it from the ignition
5- remember u r still pressing the alarm button, don't release yet
6- put the key again in the ignition
7- turn the key to position 1 once more
8- now release the alarm button
9- press the alarm button again and release immediately
10- the alarm lamp will flash
11- press any button in your car remote control key (u can press several times until you hear the alarm arming)
12- now press any key in your spare key until you hear the alarm arming again.
13- congratulations, now the key in the ignition is recoded with the car.
notes:
- if u fail to follow the procedures go to the nearest gen2 service center.
- you may need to repeat the following instructions for the spare key.
- if u don't have a spare key u can use any other gen2 key.
إعادة الترميز مفاتيح سيارتك
لأسباب غير معروفة قد تفقد مفاتيح السيارة رمز فتح أو إغلاق الأبواب و أيضا تفقد القدرة على تشغيل جهاز الانذار.
الأعراض : عدم امكنية استخدام جهاز التحكم عن بعد الموجود في مفتاح السيارة الرئيسي والاحتياطي لفتح الابواب او اغلاقها كما لا يمكن اتخدامه ايضا لتشغيل او ايقاف جهاز الانذار.
في حين تأكد ان كلا من المفاتيح تعمل بشكل جيد والبطاريات جيدة.
الحل : احصل على كل من المفتاح الأصلي والاحتياطي واتبع الخطوات التالية بعناية
1 - وضع المفتاح في المكان الخاص به لتشغيل السيارة.
2 - الضغط على زر جهاز الانذار بيدك اليسرى ولا تترك زر جهاز الانذار (زر دائري مع نقطة صغيرة بداخله يقع في لوحة القيادة)
3 – قم بادارة المفتاح الى الوضع1 (مصباح المحرك و كافة المصابيح الاخرى سوف تضيء)
4 – بعد 5 ثواني ادر المفتاح الى وضع الاغلاق واسحبه من مكانه0
5 - تذكر يجب ان تستمر بالضغط على زر جهاز الانذار ولا تتركه
6 - ضع المفتاح مرة أخرى في المكان الخاص به لتشغيل السيارة
7 - ادر المفتاح الى الوضع 1 مرة أخرى
8 - والآن اترك زر جهاز الانذار
9 - اضغط على زر جهاز الانذار مرة أخرى واتركه فورا
10 – مصباح جهاز الانذار سوف يومض
11 - اضغط على أي زر في مفتاح التحكم عن بعد ( يمكن الضغط عدة مرات حتى تسمع صوت جهاز الانذار)
12 - الآن اضغط على أي زر في المفتاح الاحتياطي حتى تسمع صوت جهاز الانذار مرة أخرى.
13 -- مبروك ، والآن المفتاح يعمل مرة اخرى مع السيارة.
ملاحظات :
-- إذا فشلت في اتباع الإجراءات تذهب إلى أقرب مركز خدمة gen2.
-- قد تحتاج إلى تكرار التعليمات التالية لتشغيل مفتاح الغيار
اعتقد يا اخي لازم تطبق الخطوات السابقة على كلا المفتاحين واذا لم تنجح برضوا الفركة بلغني وان شاء الله ها اساعد حضرتك ... .
