STARTING PROCEDURE FOR
PETROL VERSIONS
Proceed as follows:
❒ ensure that the handbrake is up;
❒ put the gear lever into neutral;
press the clutch pedal down to the
floor without touching the accelerator;
❒ turn the ignition key to AVV and let
it go the moment the engine starts.
If the engine does not start at the first at-
tempt, return the ignition key to STOP
before repeating starting.
وأنا عامل الموضوع للحكايه دي مخصوص يفضل دوس الدبرياج أثناء التدوير (عشان تقلل الحمل على المارش)
HOW TO WARM UP THE
ENGINE AFTER IT HAS JUST
STARTED
(petrol and diesel engines)
Proceed as follows:
drive off slowly, letting the engine turn
at medium revs. Do not accelerate
abruptly;
❒ do not demand to performance for the
first few kilometres. Wait until the en-
gine
coolant gauge starts moving.
سوق العربيه على طول متستناش تسخن
متقرص على العربيه غير لما عداد الحرارة يبتدي يتحرك (مقالوش لازم يوصل للنص)
