I don't know the credibility as i am not an owner of a 516 but i just posted it for the benefit of all the owners
Spark Plugs
Dimension : Specs 14mm thread size, Reach 19mm Hex Size 16mm
Factory install : Bosch FR7DTC (Triple earth electrode)
Some alternatives
BOScH FR7DC, FR7DCX etc
Denso K20PRU-11,K20PBR etc (normal),IK20 (Iridium), VK20 (Iridium/Platinum)
NGK BKR6E-11
Oil Filter
Dimensions: Height 81.8mm, Outer Diameter 82mm, Thread M20mm X 1.5mm (most important)
Factory install : Fleetguard (Shanghai factory) LF3881 Chery part no. 481H-1012010
Compatible oil filter, many Honda( e.g. 15400-PR3-0050), Mazda, Subaru,
Hyundai Sonata oil filter
Izuzu Gemini
Osaka 8-94217272-0
K&N HP-1004
FRAM PH3593A
Air filter
shape Rectangular panel, Dimensions: Height: 40 mm, Outside Length: 245 mm Outside Width: 220 mm
Chery Part no. A21-1109111
K&N
air filter 33-2658 * may fit
K&N
air filter 33-2054 * most likely to fit
Simota, ESE and hurricane
TOYOTA 1780107020, 1780146060 (alternatives are non-exact fit)
Wiper Blade
Hook type, Right 550mm Left 500mm
Factory install : Valeo, Right c/w
spoiler
Alternatives, NWB, RainX (reinstall
spoiler if possible)
Alloy wheel
Chery Part No: A21-3100020AM
ET 46 (offset in mm), 15X6JJ (15 inch, width 6 inch), max load 600kg, Bolt pattern 4X 114.3mm (4.5inch)
Tyre 195/55R15 V(speed rating)
Possible upgrade for
tyres (no inch up) 205/50R15
(inch up) 205/45R16
(2 inch up) 205/40R17
Front Brake pads
Chery Part No: A21-3501070 (for A5 1.6L w/o electronic wear sensor)
width 119mm, Height 69.5mm, Thickness 19.3mm
Friction coefficient FF (important DO NOT Downgrade)
Note : there is another part with electronic wear sensor that appears on earlier A5, Chery part no: A21-3501080
Same as old Audi front brake pads
Alternatives: FBK, Honeywell,Nbrake NDB211, Mintex MDB1190, AUDI 443698151, VW 431698151 (Please compare first)
Rear Brake pads
Chery Part No: A21-3501090
Width 107.6mm, Height 42.5mm, Thickness 16mm
Similar to Toyota Camry (V1,V10,V20,V30 etc), Toyota Corolla (E11)
Mintex MDB1994, Toyota 0446620070 etc (many different part numbers), Nbrake NDB8067, Akebono
Front Disc Rotors
Chery Part No: A21-3501075
Internally Ventilated (double layer)
Bolt pattern 4X114.3mm + single screwhole
Diameter 240mm, Brake Disc Thickness 22mm, Height 48mm, Pitch Circle 150mm, Centering Diameter 68mm (approximate measurements)
Rear Disc Rotors
Chery Part No: A21-3502075
Brake Disc Type solid
Diameter 260mm, Brake Disc Thickness 10mm, Height 60mm, Pitch Circle 182 mm, Centering Diameter 68 mm (approximate measurements)
Ignition coil
Factory Install Bosch 0 221 503 485 begin_of_the_skype_highlighting 0 221 503 485 end_of_the_skype_highlighting , Chery Part No: A11-3705110EA
Alternatives Valeo 245040, FIAT 9607405480, CITROEN 597060, PEUGEOT 597048 topline TIc 8040 (Malaysia)
Front Dampers
OEM Sachs (Shanghai)
chery part no. A21-2905010
Rear Dampers
Chery Part no. A21-2915010
Air flow sensor
4 Pins Terminal, 5V
Factory Install for 1.6L,made in Germany BOSCH 0 261 230 099 begin_of_the_skype_highlighting 0 261 230 099 end_of_the_skype_highlighting (intake manifold absolute pressure sensor), Chery part no: 480ED-108060
Alternatives FORD 2U1L 9F479 AA, OPEL 93 399 801, Honda Jazz 37830PWEG01
Note : for 2.0L, it is a different part from BoscH (also used in Audi A4 2006[])
منقول من إحدي المواقع الاجنية
