انت حتى لو كنت ناوى تغيرها لما تسمع سعرها هتغير رأيك
سعر الصباع الواحد 750 جنيه تقريبا صوابع الميزان الخلفيه
زيت الفتيس فى سمارت تقريبا 90 جنيه
Mazda3 maintenance schedule
Maintenance should occur every 4 months or every 8,000 km, depending on the frequency which you drive your vehicle.
Every 8,000 km or 4 months
Inspect engine coolant level , Inspect function of all lights, Lubricate all locks and hinges, Replace engine oil, Replace oil filter, Drive Belt Tension Inspect every 56,000 kms, Engine Valve Clearance Audible check and adjust if noisy every 120,000 kms, Replace spark plugs at 120,000 kilometres.
Every 24,000 km or 12 months
Inspect engine coolant level , Inspect function of all lights, Lubricate all locks and hinges, Replace engine oil, Replace oil filter, Inspect disc brakes (front and rear) and lubricate caliper slide rails/pins, Drive Belt Tension Inspect every 56,000 kms, Engine Valve Clearance Audible check and adjust if noisy every 120,000 kms, Replace spark plugs at 120,000 kilometres.
Every 48,000 km or 24 months
Inspect engine coolant level , Inspect function of all lights, Lubricate all locks and hinges, Replace engine oil, Replace oil filter, Replace air cleaner element, Inspect disc brakes (front and rear) and lubricate caliper slide rails/pins, Inspect brake drum system including parkingbrake, Inspect fuel lines and hoses, Inspect exhaust system and heat shields, Inspect driveshaft dust boots, Inspect all suspension components front and rear including ball joints and driveshafts, Drive Belt Tension Inspect every 56,000 kms, Engine Valve Clearance Audible check and adjust if noisy every 120,000 kms, Replace spark plugs at 120,000 kilometres.
Every 96,000 km or 48 months
Inspect engine coolant level , Inspect function of all lights, Lubricate all locks and hinges, Replace engine oil, Replace oil filter, Replace air cleaner element, Replace coolant, Inspect disc brakes (front and rear) and lubricate caliper slide rails/pins, Inspect brake drum system including parkingbrake, Inspect fuel lines and hoses, Inspect exhaust system and heat shields, Inspect driveshaft dust boots, Inspect all suspension components front and rear including ball joints and driveshafts, Inspect emission hoses and tubes, Inspect manual transmission oil, Drive Belt Tension Inspect every 56,000 kms, Engine Valve Clearance Audible check and adjust if noisy every 120,000 kms, Replace spark plugs at 120,000 kilometres.
750 جنيه ليه يعني كتير جداً طبعاً (هو أنا حاسس أنها كويسة معرفش لو غيرتها هحس بتحسن ولا لأ خصوصاً أنها مش عملالي أي مشكلة )
ده أنا كنت ناوي أغير عندهم سير
باور وسير كاتينه وفلتر هوا وفلتر بنزين شكلي هكع هناك دم قلبي
هوا أنا مكن أجيب سير الباور وسير الكتينة من العالمية برضو ، أو لو تعرف مكانيكي مازدا شاطر أخليه يبصلي على السيور اللي محتاجة تغير بدل مغير كله على الفاضي عشان عايز أفوقها بقى عشان عايز أرح أعمل فرمه الساحل :b4_033:
