ممكن تستخدم الspray بتاع الcarb &injection cleaner و ده موجود في محطات البنزين , بيستخدموه في تنظيف الMAF زي ما قريت على النت
رقم العضوية : 777
السيارة: Chery A11
السيارة[2]: BMW e46
أنا ساعات بشم ريحه زى شياط بعد ال170 و التسارع معدله بيقل قوي فقولت لسيد سعيد قاللى ده ايرماس و محتاج يتغير(سعره جديد بوش ألمانى 950جم) قولت أجرب أنضفه الأول و فعلا لقيت طريقة التظيف على النت.
المشكله انى مش عارف أجيب منين الأيرماس كلينر أو حتى أي electric cleaner علشان أقوم بالمهمة دي؟
المساعده يا شباب علما انى دورت فى كارفور.
Cleaning the Mass Air Flow Sensor
The mass air flow sensor (MAF) senses how much air is coming into the engine. The DME uses this information to calculate how much fuel it should be putting into the injectors to maintain the proper air/fuel ratio. Over time, the tiny super sensitive resistor in the MAF can get dirty - this causes it to not detect the proper amount of air. This can cause erratic idle and loss of power and gas mileage. Cleaning the MAF is even more important if you've got a cold air intake with an oil filter - the oil will collect on the MAF. These instructions are for the factory intake.
Parts/Tools required: 10mm socket, flat-bladed screwdriver, CRC Mass Air Flow Sensor Cleaner spray, Lost Coast Brewery (Eureka, CA) Downtown Brown, bottle opener
Step 1: Disconnect the MAF wiring harness. I pulled up a little retaining clip slightly with a flat-bladed screwdriver to help me pull it out:
Step 2: Unscrew the two 10mm bolts holding the airbox in place. Use your flat-bladed screwdriver to loosen the hose clamp (complete removal is not required):
Step 3: Remove air box. To do this, you'll have to pull the snorkels out of both the inlet and exhaust of the airbox. After you've done that, rotate it up and toward you from the rear until it comes free. Some jiggling may be required.
Here's a picture of the airbox coming out of the car, with the MAF pointed out:
Step 4: With the airbox out of the car, you remove the MAF by using your flat-bladed screwdriver to pry these retaining clips out of the way (two of them, one on each side):
Step 5: Follow the directions on the spray. It tells you to spray the entire screen and sensor down with fluid 10-12 times, being extra careful not to touch the straw to any ....l parts. After doing that, I held it until I couldn't smell the fluid anymore (that's my method of determining if it had all evaporated ). Replacement is the opposite of removal. Getting the airbox into place can require quite a bit of jiggling, so be patient. I haven't found any tricks, it just takes a few times to learn how it snaps into place. Be careful to pull your MAF wiring harness aside before placing your airbox into place. It sucks when you discover it's stuck under there.. (not that I'd know...).
Step 6: Open and enjoy your Downtown Brown for a job well done!
رقم العضوية : 29426
الاقامة : Netherlands
السيارة: Mini Cooper Chilli 1.6
السيارة[2]: BMW E90 318i LCI N43
رقم العضوية : 777
السيارة: Chery A11
السيارة[2]: BMW e46
رقم العضوية : 28460
الاقامة : Nasr City
السيارة: Logan 2010/Astra Cosmo 2015
السيارة[2]: Logan 2012 AT B.L
دراجة بخارية: N/A
رقم العضوية : 777
السيارة: Chery A11
السيارة[2]: BMW e46
رقم العضوية : 3258
السيارة: bmw 325 m40
السيارة[2]: passat2007
دراجة بخارية: no way
electric cleaner ممكن بتاع تنظيف هد الكاسيت و الاجهزه الكهربيه بس اهم حاجه يكون بدون زيت بيكون مكتوب عليه و ممكن تجيبه من بابا اللوق من عند اي حد بتاع الدش و الكومبيوتر هناك
نصيحة من اخ الى اخراقِبْ أفكارَكَ لأنها ستُصبِحُ أفعَالاًراقِبْ أفعالَكَ لأنها ستُصبِحُ عاداتراقِبْ عاداتَكَ لأنها ستُصبِحُ طِباعاًراقِبْ طِباعَكَ لأنها ستُحدِّدُ مصِيرَكَ
رقم العضوية : 28460
الاقامة : Nasr City
دراجة بخارية: N/A
اه ظبط معايا الحمد لله استهلاك البنزين لأن كان عندي قرايتين غلط في الfam و الtps و ظبطهم باني نضفتهم و نضفت الانجيكشن كلوا
يجب تعديل حجم الصورة
رقم العضوية : 100316
الاقامة : CAIRO
السيارة: OPEL VECTRA 1.6
السيارة[2]: BMW E30 320i I6
أنا برده مكنتش العربية متظبته نضفته ب اسبراي بتاع الاجزاء الكهربائية بيبقي من غير زيت و مرسوم علي العلبة بوردة كده و بيبقي متخصص في الحاجات ال فيها كهرباء
