tell "belya" to use the saroo7' :lol:المشاركة الأصلية كتبت بواسطة CryptonX
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
the shop should know what is compatable with your car... not all suspension parts are swappable between models
you can put monroes on the front only... but it is always better to have all 4
this is because the dealership is also called the STEALership
i have 14" steel and they are freakingly heavy... alloy wheels are lighter and 14" to 15" upgrade is not going to put too much strain on the suspension
got no recommendation for wheels... sorry
i never said i don't like to talk in english... in fact i DO love to talk in english bti always try to answer in the form that best suits the post owner
رقم العضوية : 102
دراجة بخارية: N/A
رقم العضوية : 842
الاقامة : Cairo , Egypt
السيارة: Fiat Palio 1.2 FIRE - 2006
السيارة[2]: Hyundai Elantra GL 2012
دراجة بخارية: مكواة بخار
lol Thanks alot
I think I am gonna try the front Monroes first , I have doubts tho about the shop telling me if they are good to go wtih my car or not , I am gonna give it a try , if I really felt the diffrence I am going to switch all 4 .
As for the rims , Intresting point ,I dont just want to make the car look good ,, I seriously need to increase its road holding , but isnt that going to reduce peformance as well my engine is a 1242CC - 83hp at 5500 rpm with 119 Torque .
or is it going to be the same performance but with a lousier fuel consumption ?
رقم العضوية : 102
دراجة بخارية: N/A
look... after my years of experiance i say everthing is a compromise... if you wanna better handling through rims and tires you are going to sacrifce performance, if you wanna handling through suspension you are going to sacrifice comfort... if you wanna power you are going to sacifice fuel economy and so forth... you got to sacrifice something to get another
the trick is how bad you want this and what are you willing to sacifice... a wise man can always find a point of balance between what he sacifice and what he gains
in your case you just did that...15" upgrade won't be that much heavy on the car but WILL add to handling... also monroes are going to make the suspension responce better so here is an extra gain
if you went to get 17" rims and full KONI kit for your car then people would call you crazy... the car won't be able to move off them heavy rims and won't go over 100km/h so your KONIs won'y do you any good either
83HP is not bad for a small car... mine is bigger and only got 86 yet i got 14" steel... ok they are heavy but the handling benefits were more than the lost power for me
i recon you will feel much better handling due to the rims/tires and you will like the monroes that you will get the rear set soon
رقم العضوية : 842
Thanks :) I Totally agree
Infact my main Pain is how the car handles over our bumpy rodes , its ride hight is VERY high as well .. making curves at any speed is almost a suiscide ...
that sometimes I feel I am in a floating boat not a car :D
and after the front suspension got wrecked. ... even the lightest bump makes me tremble and very unstable Inside the car , everything shakes and stuff...
again Thanks , Iwill post pics of my Installed Monroes Soon isa .
رقم العضوية : 3549
الاقامة : Giza
السيارة: لانسر بومة
السيارة[2]: Fiat Palio
دراجة بخارية: Nothing
ممكن حد يقوللي بالتفصيل اسعار قطع غيار فيات باليو 2008 الصيني
