لو حد عنده واحد زى ده ونفس الامكانيات وعايز يبيعه انا شارى باذن الله
Mosfet power supply Amplifier
Gold plated Brass Set screw Terminal
Double sided Through hole Epoxy Pcb
24db Oct. Crossover
Variable Low pass Crossover (5000hz - 2500hz)
Variable 24db Oct. High pass filter (5000hz - 2500hz)
50way Protection
Daisy chain through output Rca
Bass remote control
Power and overload Protection LED
Thermal Protection LED
1ohm Stable Circuits
Soft start/ Output relay
Max Power @ 5000ohm: 10000w
Rms power @ 2500ohm: 3000w
Dimensions (H x W x L) : 50.5 x 260 x 390 mm
- Model: STT 9000watt
- Manufactured by: Ice Power
