عادي يا باشا....هي المفروض كانت تبقى طلعت قبل الصيانةعلشان يلغوها و انت هناك....بس هي بتطلع اوتوماتيك عند كيلومتر معين
دي الطريقة علشان تلغيها:
Vehicles with Multifunction Display -
1.) With the key out of the ignition – Press and hold the “0.0”, located on the right side of the instrument cluster.
2.) While holding the reset button insert the key and turn to the “Accessory” position. Wait for “Service now!” message to appear on multi–functionscreen.
3.) Then release the “0.0” and press the “m” (minutes) button on the opposite side of the instrument cluster.
4.) To verify it’s been reset hold the ”0.0″ button again – the display should indicate the future service by the message: “Service in 5,000 mi / 8,000 KM or 180 days or 10,000 mi / 16,000 km or 365 days” depending on Service Interval adaptation.
Vehicles without Multifunction Display -
2.) While holding the ”0.0″ button insert the key and turn to the “Accessory” position. Wait for “wrench” symbol to appear in the odometer display.
3.) Then release the “0.0” and press the “MIN” button on the opposite side of the instrument cluster.
4.) To verify it’s been reset hold the ”0.0″ button again: The “wrench” symbol will appear together with the reset number of miles / kilometers you can drive until the service due date. The display changes after about 10 seconds. A “clock” symbol appears together with the reset number of days until the service due date.
