حل مشكله الناس اللي المنتدي مش بيفتح معاهم بعد تغيير السيرفر
الحل في تغيير رقم ال dns الخاص بيك
ودي الطريقه لويندوز 7
اقتباس:
1. Open the
Control Panel.
2. Open up
Network and Internet and go to the
Network and Sharing Center.
3. Click on
Change adapter settings on the left hand panel.
4. This will bring up a list of adapters present on your computer. Most people will have a
Local Area Connection while laptop users will add a
Wireless Network Connection and possibly a
Bluetooth Network Connection...go ahead and
right click on Local Area Connection and click on
Properties.
NOTE: These steps do not change if you are modifying the Wireless Network Connection instead 5. If prompted by
UAC, click on
Yes.
6. Highlight
Internet Protocol Version 4 (TCP/IPv4) and click on
properties.7. In the properties window you will see a few radio boxes with both of them saying Obtain an IP/DNS Address Automatically....we will leave the IP address alone and will
change the Obtain DNS....to use the following:
In the Preferred DNS server boxes enter this sequence: 208.67.222.222
In the Alternate DNS server boxes enter this sequence: 208.67.220.220
8. Check the
validate settings upon exit (Optional) check box, click
OK, and then
Close to finish. (See screenshot above)
9. Windows will check your settings (if you checked the option above) and you will be finished! Now start surfing to feel the effects of a quicker and more secure browsing experience!
ودي للناس اللي بيستعملوا ويندوز xp
اقتباس:
Go to
Control Panel>Network Connections and select your local network.Click
Properties, then select
Internet Protocol (TCP/IP).Click
Properties. You will see a window like the one below - this is the
Internet Protocol window. Select
"Use the following DNS server addresses" and enter the desired DNS server(s) in the space(s) provided.
انا نقلت الخطوات بدل ما اقعد اخد سكرين شوت اولا
وثانيا لاني شغال اكس بي
حنحط الدي ان اس الجديد
8.8.8.8
8.8.4.4
عملت الموضوع في المنتدي العام علشان يظهر في شريط المواضيع
واللي يعرف حد عنده مشكله في دخول المنتدي يقوله علي طريقه الحل
