شكرا علي التحذير اللي مكنتش أعرفه
أنا دورت شوية ولاقيت انه ينفع تحط فويل ولكن بدون تغطية الطعام بالكامل وده اللي انا عملته ومحصلش حاجة فعلا لاني غطيت الزجاج من فوق بس مع الأخذ في الإعتبار بالتوجيهات التالية
بس أنا معاك هحاول الاقي بديل تاني زي البلاستيك القزاز... هل فيه منه لاستخدام الميكروويف؟
Is it safe to use aluminum foil in a microwave oven?
Always consult the owner's manual of your microwave oven and heed the manufacturer's recommendations for the use of aluminum foil. It can be safe to use small amounts of aluminum foil in a microwave oven.
Microwaves cannot pass through ....l but are absorbed by food. No food completely covered by aluminum foil or in a covered ....l pan should be put in a microwave oven because food wouldn't be available to absorb the microwaves. Operating the oven empty or when the food is completely wrapped in aluminum foil can cause damage to the oven and the food won't heat.
However, small pieces of aluminum foil can be used to "shield" areas of foods, such as poultry drumsticks and wings, to prevent over.....ng.
Some food packaged in foil containers can be safe to microwave. Read the package heating instructions to see if the food manufacturer has specific recommendations for microwaving the product. Because food in these containers will only heat from the top, it's best to microwave foods only 1-2 inches in depth so food near the bottom will be heated thoroughly before food on top dries and overcooks.
General Rules for Safe Use of Aluminum Foil:
- Use new, smooth foil only. Wrinkled foil can cause arcing (sparks).
- Cover no more than 1/4 of the food with foil.
- Shape the foil smoothly to the food so no edges stick out.
- It makes no difference which side of foil (shiny or dull) is facing out.
- Do not place the foil closer than one inch from the oven walls.
- If the microwave oven has ....l ....ves OR a ....l turntable, don't microwave food in foil containers or ....l pans, and don't let foil used for shielding touch or be close to the ....ves or turntable.
- If you see arcing (sparks), immediately remove the foil shielding; transfer frozen food from foil container to a microwave-safe utensil.
