Microwave Oven Safety Standard
The Food and Drug Administration (FDA) has the responsibility for carrying out an electronic
product radiation control program mandated by the Electronic Product Radiation Control provisions of the Food Drug and Cosmetic Act. Through its Center for Devices and Radiological Health, FDA sets and enforces standards of performance for electronic products to assure that radiation emissions do not pose a hazard to public health.
A Federal standard limits the amount of microwaves that can leak from an oven throughout its lifetime to 5 milliwatts (mW) of microwave radiation per square centimeter at approximately 2 inches from the oven surface. This limit is far below the level known to harm people. Microwave energy also decreases dramatically as you move away from the source of radiation. A measurement made 20 inches from an oven would be approximately one one-hundredth of the value measured at 2 inches.
The standard also requires all ovens to have two independent interlock systems that stop the production of microwaves the moment the latch is released or the door opened. In addition, a monitoring system stops oven operation in case one or both of the interlock systems fail. The noise that many ovens continue to make after the door is open is usually the fan. The noise does not mean that microwaves are being produced. There is no residual radiation remaining after microwave production has stopped. In this regard a microwave oven is much like an electric light that stops glowing when it is turned off.
All ovens must have a label stating that they meet the safety standard. In addition, FDA requires that all ovens have a label explaining precautions for use. This requirement may be dropped if the manufacturer has proven that the oven will not exceed the allowable leakage limit even if used under the conditions cautioned against on the label.
To make sure the standard is met, FDA tests microwave ovens in its own laboratory. FDA also evaluates manufacturers' radiation testing and quality control programs at their factories.
Although FDA believes the standard assures that microwave ovens do not present any radiation hazard, the Agency continues to reassess its adequacy as new information becomes available.
Microwave Ovens and Health
Much research is under way on microwaves and how they might affect the human body. It is known that microwave radiation can heat body tissue the same way it heats food. Exposure to high levels of microwaves can cause a painful burn. The lens of the eye is particularly sensitive to intense heat, and exposure to high levels of microwaves can cause cataracts. Likewise, the testes are very sensitive to changes in temperature. Accidental exposure to high levels of microwave energy can alter or kill sperm, producing temporary sterility. But these types of injuries - burns, cataracts, temporary sterility - can only be caused by exposure to large amounts of microwave radiation, much more than the 5mW limit for microwave oven leakage.
Less is known about what happens to people exposed to low levels of microwaves. Controlled, long-term studies involving large numbers of people have not been conducted to assess the impact of low level microwave energy on humans. Much research has been done with experimental animals, but it is difficult to translate the effects of microwaves on animals to possible effects on humans. For one thing, there are differences in the way animals and humans absorb microwaves. For another, experimental conditions can't exactly simulate the conditions under which people use microwave ovens. However, these studies do help us better understand the possible effects of radiation.
The fact that many scientific questions about exposure to low-levels of microwaves are not yet answered require FDA to continue to enforcement of radiation protection requirements. Consumers should take certain common sense precautions.
Have Radiation Injuries Resulted from Microwave Ovens?
There have been allegations of radiation injury from microwave ovens, but none as a direct result of microwave exposure. The injuries known to FDA have been injuries that could have happened with any oven or .....ng surface. For example, many people have been burned by the hot food, splattering grease, or steam from food .....d in a microwave oven.
