Manufacturer OPEL
Model Vectra Stroke cc 1998
Kilowatts 100
Fuel Type Petrol
Number Of Cylinders 4
Engine Type DOHC
Engine Code X20XEV
From08-1992 to 06-2000
Part No.
TypeComments
60078ABS SensorFront
Replaces Bosch0 265 001 206 GM90287309 Opel530436
#990000
60078ABS SensorFitting Position Front Axle
#ff0000
19657Air Mass Meter
Replaces GM836569 GM9041 1957 Siemens VDO5WK9150 Siemens VDO5WK9150Z
#ff0000
55718Air Temperature Sensor
Replaces GM6238331 GM90499898 LucasSNB988 Siemens VDO5WK96061
#ff0000
51661Brake light Switch
Replaces GM09175172 GM9175172 Opel1239448
#ff0000
51673
Brake light Switch
Replaces Febi21304 GM09132299 GM9132299 Opel1240008
Comments Adjustable Plunger 2 Terminals N/C circuit
#ff0000
51720Brake light Switch2 Terminals
Replaces Chevrolet94580647 Chevrolet96567247 Daewoo90196375 Daewoo94580647 Daewoo96567247 Febi02803 GM1239433 GM1240591 GM90196375 GM90504499 GM94580647 GM96567247 Holden90196375 Land RoverXKB100080L LucasSMB432 RoverXKB100080
51723Brake light Switch
Replaces Daewoo96212027 GM90307473 Holden90307473 LucasSMB558 Opel1240596
#ff0000
18960Camshaft Sensor
Replaces Febi18169 GM1238915 GM90458252 LucasSEB491 Siemens5WK90551
#ff0000
19046Camshaft SensorModified type with Harness
Replaces Febi24865 GM24445139 GM9012039 GM93171450 LucasSEB1132 Siemens VDO5WK90552 Siemens VDO5WK90554 VemoV40-72-0397
Comments Modified type with Harness
#ff0000
18961Crankshaft Sensorconnector with 4 runners
Replaces Febi18163 GM09174621 GM1238228 GM6238377 GM90506103 GM9174621 LucasSEB490 Siemens VDO5WK96071 Siemens VDOS103857002Z VemoV40-72-0305
#ff0000
18962Crankshaft Sensorconnector with 3 runners
Replaces GM1238914 GM90458251 LucasSEB985 Siemens5WK90541 Siemens5WK90541Z
#ff0000
51529Cruise Control Switch Clutch10/95-09/00
Replaces BMW61318360421 BMW8360421 GM1239435 GM1239443 GM90494519 GM90569685 LucasSMB582
Comments Adjustable Plunger 2 Round Terminals N/O circuit
#ff0000
14308
EGR Valve11/93-08/01
Replaces DelphiEG10276 DelphiEG10276-12B1 GM5851002 GM5851012 GM90469560 GM90541129 Pierburg7.21898.00.0
Comments Pneumatic
#ff0000
14904EGR Valve
Replaces DelphiEG10006 DelphiEG10006-12B1 GM17098361 GM5851025 GM5851603 GM851025 GM93184996 LucasFDR129 Pierburg7.24809.02.0 Pierburg7.24809.12.0
#ff0000
14215Electric Valve06/94-09/00
Replaces DelphiSL10002 DelphiSL10002-12B1 GM1997199 GM807446
Comments Canister Purge Valve
#ff0000
55127Engine Management Temperature SensorBlue top
Replaces Febi17697 GM1342850 GM4500001 GM90411977 LucasSNB929 Siemens5WK90601
Comments 2 Terminals M12 x 1.5 Thread Blue top
#ff0000
55127Engine Management Temperature Sensor4x4 Blue top
#ff0000
55529Engine Management Temperature SensorGrey top
Replaces GM1342855 GM90573077 LucasSNB852
Comments 2 Terminals M12 x 1.5 Thread Grey top
#ff0000
58900Flasher Unit
Replaces BMW12111364984 BMW12111365113 BMW61311371907 Bosch0 335 200 004 Bosch0 335 200 022 Bosch0 335 200 024 Bosch0 335 200 027 Bosch0 335 200 038 Bosch0 335 200 050 Bosch0 335 200 052 Febi04633 Febi11574 Fiat82430021 Ford6048781 GM90057384 GM91005213 GM9285484 GM92854847 Hyundai95550-21002 Lada2108-3747010 Land RoverRTC3234 Lucas35067 Lucas35080 Lucas35088 Lucas35089 Lucas35093 LucasSFB151 LucasSFB152 LucasSFB155 LucasSFB156 LucasSFB158 LucasSFB162 Nissan25730-16B00 Opel1226919 Reliant220646 RoverADU5260 RoverDRC8626 Saab8583627 SEVEFU3 Toyota81980-12070 VAG111 953 227A VAG111 953 227B VAG111 953 227D VAG191 953 227A Volvo1363786-3 Volvo3273203-4
#ff0000
58940Flasher UnitFor Trailer
Replaces Alfa Romeo60538839 BMW61311372021 Bosch0 335 200 041 Bosch0 335 200 051 Bosch0 335 200 077 Febi22605 GM8862228 GM9962228 Land RoverPRC8876 Lucas35063 LucasSFB164 LucasSFB180 Rover83H1010 VAG431 953 231 Volvo1323317-6
#ff0000
14734Fuel Injector
Replaces Bosch0 280 155 712 GM90467576 GM90487344 GM90490989 GM90543624 LucasFDB337 Saab4770392 Saab5959622 Volvo9125118
#ff0000
16537Fuel Pressure Regulator4x4
Replaces GM815510 GM90411542 LucasFDB1023
#ff0000
31543Fuel Pump
Replaces Bosch0 580 453 966 Bosch0580453966 GM815019 GM90411794 GM90442231 LucasFDB1037
#ff0000
31598Fuel Pump
Replaces GM815037 GM815039 GM9120218 GM9200109 LucasFDB1062 LucasFDB756
#ff0000
59150Fuel Pump Relay
Replaces Febi01483 GM1238539 GM1238540 GM1238549 GM1238966 GM90225811 GM90230894 GM90240698 GM90378651 LucasFDB504
#ff0000
59178Fuel Pump Relay
Replaces GM6238543 GM90494959 LucasFDB1089
#ff0000
14773Idle Control Valve
Replaces Alfa Romeo195321101000 Alfa Romeo195321101701 Alfa Romeo605132070 Bosch0 280 140 516 Fiat60513207 Fiat6081337 Fiat7766481 GM837101 GM90271799 Iveco7766481 Iveco8011038 Lancia6021337 Lancia60513207 Lancia7766481 LucasFDB968 PSA0345 42 PSA91540797 PSA96000803680 PSA96008036 Renault77 00 271 089 Saab758601 Saab7586019 VAG026 906 049 6 Volvo1389618 Volvo1398618 Volvo3450181
#ff0000
14802Idle Control Valve
Replaces Febi18643 GM837102 GM90411546 HitachiAESP207-13A LucasFDB947 Siemens5WK90361X SiemensX10-739-002-001
#ff0000
12678Ignition Coil
Replaces BBTIC07100 GM1208071 GM90458250 LucasDMB800 Sagem2526055A Siemens5WK 0611 Siemens5WK90611 Valeo245057 Valeo2526055 ValeoCD440
73806Ignition Lead Set
Replaces BBTZK777 BoschB237 ChampionLS095 ChampionLS340 CIXC459 CIXC647 Delco RemyDRL372 EuroCable4715 GM90487571 GM96460220 JanmorD16S JanmorODS241 LucasDKB468 MTA20.22269 NGKRC-OP440 NippartsJ5380905 Opel1612598 PowerTecPT686 ProSparkOES645 Sentech8164 SoverignSL173 SoverignSL529 SoverignSL586 SoverignSL652
#ff0000
19522Knock Sensor06/94-09/00
Replaces Daewoo90411972 Daewoo94580819 Daewoo96508199 GM6238312 GM90411972 Holden90411972 LucasSEB1078 Siemens VDO5WK90561 Siemens VDOS103057001Z
#ff0000
50935Oil Pressure Switch
Replaces Chevrolet90336039 Chevrolet95961350 Chevrolet96281689 Chevrolet96494264 Chevrolet96647339 Daewoo90336039 Daewoo95961350 Daewoo96281689 Daewoo96494264 Daewoo96647339 Febi06972 Febi09017 Febi17664 GM1252557 GM1252562 GM1252570 GM1252572 GM1252578 GM4803551 GM55354378 GM90335039 GM90336039 GM90507539 GM90569684 GM93318082 GM95961350 GM96494264 Holden90336039 Holden90507539 LucasSOB709 Saab4504585 Saab4770186 Saab5962816 Saab90569684 Saab9544610
Comments 1 Terminal in Block M14 x 1.5 4.4-8.0PSI .29-.53Bar N/C
#ff0000
13192Oxygen Sensor03/99-->Precat
Replaces GM855 342 GM90 530 586 LucasLEB299 NGKOTA7N-5A1 NTK1920 NTKOTA7N-5A1
#ff0000
16379Oxygen Sensor
Precat
16355 Replaces GM855330 GM90411959 GM90528253 LucasLEB216 LucasSEB216 NTK0442 NTKOTA7L-3C3 Opel90258253
Comments Titania Sensor
#ff0000
16380Oxygen Sensor
16355Replaces GM90411959 LucasLEB219 LucasSEB219 NTK1954 NTKOTA7H-3C1
#ff0000
50134Radiator Fan Switch
Replaces Fiat7586250 GM90357303 Holden90357303 LucasSNB1038 Opel1341028 Valeo820242
Comments 2 Terminals in Block M22 x 1.5 87-82deg C N/O
#ff0000
50188Radiator Fan SwitchA/C
Replaces GM90376209 Holden90376209 LucasSNB669 Opel1846325 Valeo820311
Comments 3 Terminals M22 x 1.5 105-100/120-115deg C N/O-N/C
#ff0000
50194Radiator Fan Switch
Replaces GM90355880 Holden90355880 Holden91151202 LucasSNB775 Opel1341039 Opel1341044
Comments 3 Terminals in Block M22 x 1.5 105-100/95-90deg C N/O
#ff0000
50195Radiator Fan SwitchA/F Size 29 M22 x 1.5 T° 100-95
Replaces Febi04777 GM90242277 GM90506496 Holden90242277 LucasSNB749 Opel1341011 Opel1341047 Valeo819830
Comments 2 Terminals in Block M22 x 1.5 100-95deg C N/O
#ff0000
50228Radiator Fan Switch
Replaces GM90357304 Holden90357304 LucasSNB672 Opel1846326
Comments 3 Terminals in Block M22 x 1.5 95-90/120-115deg C N/C-N/O
#ff0000
50465Radiator Fan Switchwith A/C
Replaces GM90506499 LucasSNB675 Opel1341043 Valeo820243
Comments 3 Terminals M22 x 1.5 110-105/120-115deg C N/C, N/O
#ff0000
50498Radiator Fan Switchwith/without A/C
Replaces GM90506498 LucasSNB674 Opel1341042 Valeo820241
Comments 3 Terminals M22 x 1.5 100-95/105-100deg C N/O
#ff0000
54601Reversing Light Switch
Replaces Daewoo90245033 Daewoo96192077 Febi02800 Fiat71719525 GM90245033 GM90482454 Holden90482454 LucasSMB512 Mini23117527716 Opel1239266 Opel1239271 RoverUMB100090 Saab4232666 Saab4617668
#ff0000
52820Temperature Transmitter
Replaces Daewoo03439088 DelcoSU31 Febi01651 GM03439088 GM90246852 GM94472002 LucasSNB117 Opel1338448 Opel1342561 Opel1342568 SmithsA-TT17 Valeo700005 VemoV40-72-0320
Comments 1 Mushroom Terminal 1/8" x 27NPTF Thread
#ff0000
75182Thermostat
Replaces GM90 501 081 GM90501081 Opel1338079 Valeo820141 Vauxhall1338079
Comments 92 degrees C
#ff0000
19908Throttle Position Sensor
Replaces Alfa Romeo605493590 Bosch0 280 122 001 Bosch0 280 122 004 Bosch0 280 122 008 Daf1292636 Ferrari142434 Fiat60549359 Fiat7637025 Fiat9603893880 Fiat9946862 GM826924 GM90323839 Hyundai31570-22010 Hyundai35170-22001 Kia0K011-18-911 KiaOK01118911 LucasSEB210 Pierburg4.02003.24.0 Pierburg4.02003.50.0 Porsche94460611600 Porsche94460616600 PSA1628 L1 PSA72408124 PSA96038938 Renault77 01 047 921 Saab885719 Saab8857915 VemoV40-72-0321 Volvo1336385 Volvo3450030
#ff0000
16355Universal Oxygen Sensor
Replaces LucasLEB231 LucasSEB231
Comments 4 wire 18mm thread Titania
#ff0000
#ff0000
#ff0000
ManufacturerOPEL
ModelVectra
Stroke cc1998
Kilowatts85
Fuel TypePetrol
Number Of Cylinders4
Engine TypeDOHC
Engine CodeC20SEL
From07-2000
Till07-2003
14215Electric Valve10/95-09/00
50935Oil Pressure Switch10/95-09/00
#ff0000
#ff0000
#ff0000
ManufacturerOPEL
ModelVectra
Stroke cc1598
Kilowatts74
Fuel TypePetrol
Engine TypeDOHC
Engine CodeX16XEL
From09-1995
Till06-2000
Part No.TypeCommentsFitmentUniversal Part No. 55717Air Temperature Sensor2 Terminals 10/95-04/02
51673Brake light Switch
18994Camshaft Sensor
18872Crankshaft Sensor>Ch.No.W1285446/W5276825/W7154258
18907Crankshaft SensorCh.No.W1285447/W7154259>
18909Crankshaft Sensor98->
14901EGR Valve>Ch.No.W1238518
14904EGR ValveCh.No.W1285447>
14215Electric Valve10/95-07/02
55450Engine Management Temperature SensorBlue top
55526Engine Management Temperature SensorLight-Blue / White / Black top
58900Flasher Unit
31598Fuel Pump
14847Idle Control Valve
12723Ignition Coil
73367Ignition Lead Set
Part No.TypeCommentsFitmentUniversal Part No. 19516Knock Sensor2 Terminals 10/95-04/02
16800MAP Sensor
16814MAP Sensor
13178Oxygen Sensor
Precat
16334 16329Oxygen Sensor1 wire Ch.no.->W1285446,W5276825,W7154258 Precat
16331 50195Radiator Fan SwitchA/C
50498Radiator Fan Switchwith A/C
75180Thermostat
19910Throttle Position Sensor
19910Throttle Position SensorMPI
16331Universal Oxygen Sensor
#ff0000
#ff0000
#ff0000
ManufacturerOPEL
ModelVectra
Stroke cc1598
Kilowatts55
Fuel TypePetrol
Engine TypeSOHC/OHC
Engine CodeX16SZR
From09-1995
Till07-2003
Part No.TypeCommentsFitmentUniversal Part No. 51661Brake light Switch
12917Coil and ModuleCoil with module Distributorless
18764Crankshaft Sensor
18835Crankshaft Sensor
14901EGR Valve
14215Electric Valve10/95-04/02
58900Flasher Unit
14800Idle Control Valve
83081Ignition Lead Set
16800MAP Sensor
16329Oxygen Sensor1 wire Precat
16331 50188Radiator Fan SwitchA/C
Part No.TypeCommentsFitmentUniversal Part No. 50195Radiator Fan SwitchA/F Size 29 M22 x 1.5 T° 100-95
50465Radiator Fan SwitchA/C
50498Radiator Fan SwitchA/C
49190sRotor ArmBosch/Valeo
75011Thermostat
19909Throttle Position SensorSPI
#ff0000
#ff0000
#ff0000
ManufacturerOPEL
ModelVectra
Stroke cc1598
Kilowatts55
Fuel TypePetrol
Engine TypeSOHC/OHC
Engine CodeC16NZ2
From08-1992
Till11-1995
Part No.TypeCommentsFitmentUniversal Part No. 60078ABS SensorFront
44850Distributor CapKAT Delco
44850Distributor CapDelco
45772Distributor CapBosch/Valeo
14900EGR Valve12/93->
55523Engine Management Temperature Sensoroil temp. sensor
58900Flasher Unit
31538Fuel Pump
12203Ignition CoilC16NZ2 Ducellier Ignition
12626Ignition CoilKAT Delco
12626Ignition CoilX16SZ Del system
Part No.TypeCommentsFitmentUniversal Part No. 76332Ignition Lead Set>>Engine No 02N52986SAE
76333Ignition Lead SetChassis No R100001,R5000001,R7500001>>SAE
73866Ignition Lead SetWithout Heat Shields - With Coil LeadM4
73976Ignition Lead SetEngine No 02N52987>>SAE
15230Ignition ModuleKAT Delco
15440Ignition ModuleDucellier Ignition
15883Ignition Module88-92
16800MAP Sensor
16331 14012Pickup CoilKAT Delco
14012Pickup CoilX16SZ Del system
50188Radiator Fan SwitchA/F Size 29 M22 x 1.5 T° 120-115/105-100
50193Radiator Fan SwitchA/F Size 29 M22 x 1.5 T° 100-95
50196Radiator Fan SwitchA/F Size 29 M22 x 1.5 T° 100-95
50228Radiator Fan SwitchA/C
47861Rotor ArmKAT Delco
Part No.TypeCommentsFitmentUniversal Part No. 47861Rotor ArmDelco
75011Thermostat
75239Thermostat
#ff0000
