النتائج 1 إلى 10 من 12
    الصورة الرمزية kornclub
    رقم العضوية : 102534
    السيارة: Opel astra 2007
    السيارة[2]: vectra 2000B
    دراجة بخارية: i wish
    الحالة : kornclub غير متواجد حالياً
    افتراضي معلومات تهمك عن سيارتك الاوبل - Facebook Twitter whatsapp انشر الموضوع فى :
    Manufacturer OPEL
    Model Vectra
    Stroke cc 1998
    Kilowatts 100
    Fuel Type Petrol
    Number Of Cylinders 4
    Engine Type DOHC
    Engine Code X20XEV
    From08-1992 to 06-2000
    Part No.
    TypeComments
    60078ABS SensorFront
    Replaces Bosch0 265 001 206 GM90287309 Opel530436
    #990000
    60078ABS SensorFitting Position Front Axle
    #ff0000
    19657Air Mass Meter
    Replaces GM836569 GM9041 1957 Siemens VDO5WK9150 Siemens VDO5WK9150Z
    #ff0000
    55718Air Temperature Sensor
    Replaces GM6238331 GM90499898 LucasSNB988 Siemens VDO5WK96061
    #ff0000
    51661Brake light Switch
    Replaces GM09175172 GM9175172 Opel1239448
    #ff0000
    51673
    Brake light Switch
    Replaces Febi21304 GM09132299 GM9132299 Opel1240008Comments Adjustable Plunger 2 Terminals N/C circuit
    #ff0000
    51720Brake light Switch2 Terminals
    Replaces Chevrolet94580647 Chevrolet96567247 Daewoo90196375 Daewoo94580647 Daewoo96567247 Febi02803 GM1239433 GM1240591 GM90196375 GM90504499 GM94580647 GM96567247 Holden90196375 Land RoverXKB100080L LucasSMB432 RoverXKB100080Comments Adjustable Plunger 2 Terminals N/C circuit
    51723Brake light Switch
    Replaces Daewoo96212027 GM90307473 Holden90307473 LucasSMB558 Opel1240596Comments Adjustable Plunger 2 Terminals N/C circuit
    #ff0000
    18960Camshaft Sensor
    Replaces Febi18169 GM1238915 GM90458252 LucasSEB491 Siemens5WK90551
    #ff0000
    19046Camshaft SensorModified type with Harness
    Replaces Febi24865 GM24445139 GM9012039 GM93171450 LucasSEB1132 Siemens VDO5WK90552 Siemens VDO5WK90554 VemoV40-72-0397Comments Modified type with Harness
    #ff0000
    18961Crankshaft Sensorconnector with 4 runners
    Replaces Febi18163 GM09174621 GM1238228 GM6238377 GM90506103 GM9174621 LucasSEB490 Siemens VDO5WK96071 Siemens VDOS103857002Z VemoV40-72-0305
    #ff0000
    18962Crankshaft Sensorconnector with 3 runners
    Replaces GM1238914 GM90458251 LucasSEB985 Siemens5WK90541 Siemens5WK90541Z
    #ff0000
    51529Cruise Control Switch Clutch10/95-09/00
    Replaces BMW61318360421 BMW8360421 GM1239435 GM1239443 GM90494519 GM90569685 LucasSMB582Comments Adjustable Plunger 2 Round Terminals N/O circuit
    #ff0000
    14308
    EGR Valve11/93-08/01
    Replaces DelphiEG10276 DelphiEG10276-12B1 GM5851002 GM5851012 GM90469560 GM90541129 Pierburg7.21898.00.0Comments Pneumatic
    #ff0000
    14904EGR Valve
    Replaces DelphiEG10006 DelphiEG10006-12B1 GM17098361 GM5851025 GM5851603 GM851025 GM93184996 LucasFDR129 Pierburg7.24809.02.0 Pierburg7.24809.12.0
    #ff0000
    14215Electric Valve06/94-09/00
    Replaces DelphiSL10002 DelphiSL10002-12B1 GM1997199 GM807446Comments Canister Purge Valve
    #ff0000
    55127Engine Management Temperature SensorBlue top
    Replaces Febi17697 GM1342850 GM4500001 GM90411977 LucasSNB929 Siemens5WK90601Comments 2 Terminals M12 x 1.5 Thread Blue top
    #ff0000
    55127Engine Management Temperature Sensor4x4 Blue top
    #ff0000
    55529Engine Management Temperature SensorGrey top
    Replaces GM1342855 GM90573077 LucasSNB852Comments 2 Terminals M12 x 1.5 Thread Grey top
    #ff0000
    58900Flasher Unit
    Replaces BMW12111364984 BMW12111365113 BMW61311371907 Bosch0 335 200 004 Bosch0 335 200 022 Bosch0 335 200 024 Bosch0 335 200 027 Bosch0 335 200 038 Bosch0 335 200 050 Bosch0 335 200 052 Febi04633 Febi11574 Fiat82430021 Ford6048781 GM90057384 GM91005213 GM9285484 GM92854847 Hyundai95550-21002 Lada2108-3747010 Land RoverRTC3234 Lucas35067 Lucas35080 Lucas35088 Lucas35089 Lucas35093 LucasSFB151 LucasSFB152 LucasSFB155 LucasSFB156 LucasSFB158 LucasSFB162 Nissan25730-16B00 Opel1226919 Reliant220646 RoverADU5260 RoverDRC8626 Saab8583627 SEVEFU3 Toyota81980-12070 VAG111 953 227A VAG111 953 227B VAG111 953 227D VAG191 953 227A Volvo1363786-3 Volvo3273203-4
    #ff0000
    58940Flasher UnitFor Trailer
    Replaces Alfa Romeo60538839 BMW61311372021 Bosch0 335 200 041 Bosch0 335 200 051 Bosch0 335 200 077 Febi22605 GM8862228 GM9962228 Land RoverPRC8876 Lucas35063 LucasSFB164 LucasSFB180 Rover83H1010 VAG431 953 231 Volvo1323317-6
    #ff0000
    14734Fuel Injector
    Replaces Bosch0 280 155 712 GM90467576 GM90487344 GM90490989 GM90543624 LucasFDB337 Saab4770392 Saab5959622 Volvo9125118
    #ff0000
    16537Fuel Pressure Regulator4x4
    Replaces GM815510 GM90411542 LucasFDB1023
    #ff0000
    31543Fuel Pump
    Replaces Bosch0 580 453 966 Bosch0580453966 GM815019 GM90411794 GM90442231 LucasFDB1037
    #ff0000
    31598Fuel Pump
    Replaces GM815037 GM815039 GM9120218 GM9200109 LucasFDB1062 LucasFDB756
    #ff0000
    59150Fuel Pump Relay
    Replaces Febi01483 GM1238539 GM1238540 GM1238549 GM1238966 GM90225811 GM90230894 GM90240698 GM90378651 LucasFDB504
    #ff0000
    59178Fuel Pump Relay
    Replaces GM6238543 GM90494959 LucasFDB1089
    #ff0000
    14773Idle Control Valve
    Replaces Alfa Romeo195321101000 Alfa Romeo195321101701 Alfa Romeo605132070 Bosch0 280 140 516 Fiat60513207 Fiat6081337 Fiat7766481 GM837101 GM90271799 Iveco7766481 Iveco8011038 Lancia6021337 Lancia60513207 Lancia7766481 LucasFDB968 PSA0345 42 PSA91540797 PSA96000803680 PSA96008036 Renault77 00 271 089 Saab758601 Saab7586019 VAG026 906 049 6 Volvo1389618 Volvo1398618 Volvo3450181
    #ff0000
    14802Idle Control Valve
    Replaces Febi18643 GM837102 GM90411546 HitachiAESP207-13A LucasFDB947 Siemens5WK90361X SiemensX10-739-002-001
    #ff0000
    12678Ignition Coil
    Replaces BBTIC07100 GM1208071 GM90458250 LucasDMB800 Sagem2526055A Siemens5WK 0611 Siemens5WK90611 Valeo245057 Valeo2526055 ValeoCD44073806Ignition Lead Set
    Replaces BBTZK777 BoschB237 ChampionLS095 ChampionLS340 CIXC459 CIXC647 Delco RemyDRL372 EuroCable4715 GM90487571 GM96460220 JanmorD16S JanmorODS241 LucasDKB468 MTA20.22269 NGKRC-OP440 NippartsJ5380905 Opel1612598 PowerTecPT686 ProSparkOES645 Sentech8164 SoverignSL173 SoverignSL529 SoverignSL586 SoverignSL652
    #ff0000
    19522Knock Sensor06/94-09/00
    Replaces Daewoo90411972 Daewoo94580819 Daewoo96508199 GM6238312 GM90411972 Holden90411972 LucasSEB1078 Siemens VDO5WK90561 Siemens VDOS103057001Z
    #ff0000
    50935Oil Pressure Switch
    Replaces Chevrolet90336039 Chevrolet95961350 Chevrolet96281689 Chevrolet96494264 Chevrolet96647339 Daewoo90336039 Daewoo95961350 Daewoo96281689 Daewoo96494264 Daewoo96647339 Febi06972 Febi09017 Febi17664 GM1252557 GM1252562 GM1252570 GM1252572 GM1252578 GM4803551 GM55354378 GM90335039 GM90336039 GM90507539 GM90569684 GM93318082 GM95961350 GM96494264 Holden90336039 Holden90507539 LucasSOB709 Saab4504585 Saab4770186 Saab5962816 Saab90569684 Saab9544610Comments 1 Terminal in Block M14 x 1.5 4.4-8.0PSI .29-.53Bar N/C
    #ff0000
    13192Oxygen Sensor03/99-->Precat
    Replaces GM855 342 GM90 530 586 LucasLEB299 NGKOTA7N-5A1 NTK1920 NTKOTA7N-5A1
    #ff0000
    16379Oxygen Sensor
    Precat16355
    Replaces GM855330 GM90411959 GM90528253 LucasLEB216 LucasSEB216 NTK0442 NTKOTA7L-3C3 Opel90258253Comments Titania Sensor
    #ff0000
    16380Oxygen Sensor
    16355Replaces GM90411959 LucasLEB219 LucasSEB219 NTK1954 NTKOTA7H-3C1
    #ff0000
    50134Radiator Fan Switch
    Replaces Fiat7586250 GM90357303 Holden90357303 LucasSNB1038 Opel1341028 Valeo820242Comments 2 Terminals in Block M22 x 1.5 87-82deg C N/O
    #ff0000
    50188Radiator Fan SwitchA/C
    Replaces GM90376209 Holden90376209 LucasSNB669 Opel1846325 Valeo820311Comments 3 Terminals M22 x 1.5 105-100/120-115deg C N/O-N/C
    #ff0000
    50194Radiator Fan Switch
    Replaces GM90355880 Holden90355880 Holden91151202 LucasSNB775 Opel1341039 Opel1341044Comments 3 Terminals in Block M22 x 1.5 105-100/95-90deg C N/O
    #ff0000
    50195Radiator Fan SwitchA/F Size 29 M22 x 1.5 T° 100-95
    Replaces Febi04777 GM90242277 GM90506496 Holden90242277 LucasSNB749 Opel1341011 Opel1341047 Valeo819830Comments 2 Terminals in Block M22 x 1.5 100-95deg C N/O
    #ff0000
    50228Radiator Fan Switch
    Replaces GM90357304 Holden90357304 LucasSNB672 Opel1846326Comments 3 Terminals in Block M22 x 1.5 95-90/120-115deg C N/C-N/O
    #ff0000
    50465Radiator Fan Switchwith A/C
    Replaces GM90506499 LucasSNB675 Opel1341043 Valeo820243Comments 3 Terminals M22 x 1.5 110-105/120-115deg C N/C, N/O
    #ff0000
    50498Radiator Fan Switchwith/without A/C
    Replaces GM90506498 LucasSNB674 Opel1341042 Valeo820241Comments 3 Terminals M22 x 1.5 100-95/105-100deg C N/O
    #ff0000
    54601Reversing Light Switch
    Replaces Daewoo90245033 Daewoo96192077 Febi02800 Fiat71719525 GM90245033 GM90482454 Holden90482454 LucasSMB512 Mini23117527716 Opel1239266 Opel1239271 RoverUMB100090 Saab4232666 Saab4617668
    #ff0000
    52820Temperature Transmitter
    Replaces Daewoo03439088 DelcoSU31 Febi01651 GM03439088 GM90246852 GM94472002 LucasSNB117 Opel1338448 Opel1342561 Opel1342568 SmithsA-TT17 Valeo700005 VemoV40-72-0320Comments 1 Mushroom Terminal 1/8" x 27NPTF Thread
    #ff0000
    75182Thermostat
    Replaces GM90 501 081 GM90501081 Opel1338079 Valeo820141 Vauxhall1338079Comments 92 degrees C
    #ff0000
    19908Throttle Position Sensor
    Replaces Alfa Romeo605493590 Bosch0 280 122 001 Bosch0 280 122 004 Bosch0 280 122 008 Daf1292636 Ferrari142434 Fiat60549359 Fiat7637025 Fiat9603893880 Fiat9946862 GM826924 GM90323839 Hyundai31570-22010 Hyundai35170-22001 Kia0K011-18-911 KiaOK01118911 LucasSEB210 Pierburg4.02003.24.0 Pierburg4.02003.50.0 Porsche94460611600 Porsche94460616600 PSA1628 L1 PSA72408124 PSA96038938 Renault77 01 047 921 Saab885719 Saab8857915 VemoV40-72-0321 Volvo1336385 Volvo3450030
    #ff0000
    16355Universal Oxygen Sensor
    Replaces LucasLEB231 LucasSEB231Comments 4 wire 18mm thread Titania
    #ff0000
    #ff0000
    #ff0000
    ManufacturerOPELModelVectraStroke cc1998Kilowatts85Fuel TypePetrolNumber Of Cylinders4Engine TypeDOHCEngine CodeC20SELFrom07-2000Till07-2003
    14215Electric Valve10/95-09/00
    50935Oil Pressure Switch10/95-09/00
    #ff0000
    #ff0000
    #ff0000
    ManufacturerOPELModelVectraStroke cc1598Kilowatts74Fuel TypePetrolNumber Of Cylinders4Engine TypeDOHCEngine CodeX16XELFrom09-1995Till06-2000Part No.TypeCommentsFitmentUniversal Part No.
    55717Air Temperature Sensor2 Terminals 10/95-04/02
    51673Brake light Switch
    18994Camshaft Sensor
    18872Crankshaft Sensor>Ch.No.W1285446/W5276825/W7154258
    18907Crankshaft SensorCh.No.W1285447/W7154259>
    18909Crankshaft Sensor98->
    14901EGR Valve>Ch.No.W1238518
    14904EGR ValveCh.No.W1285447>
    14215Electric Valve10/95-07/02
    55450Engine Management Temperature SensorBlue top
    55526Engine Management Temperature SensorLight-Blue / White / Black top
    58900Flasher Unit
    31598Fuel Pump
    14847Idle Control Valve
    12723Ignition Coil
    73367Ignition Lead Set
    19516Knock Sensor2 Terminals 10/95-04/02
    16800MAP Sensor
    16814MAP Sensor
    13178Oxygen Sensor
    Precat16334
    16329Oxygen Sensor1 wire Ch.no.->W1285446,W5276825,W7154258 Precat16331
    50195Radiator Fan SwitchA/C
    50498Radiator Fan Switchwith A/C
    75180Thermostat
    19910Throttle Position Sensor
    19910Throttle Position SensorMPI
    16331Universal Oxygen Sensor
    #ff0000
    #ff0000
    #ff0000
    ManufacturerOPELModelVectraStroke cc1598Kilowatts55Fuel TypePetrolNumber Of Cylinders4Engine TypeSOHC/OHCEngine CodeX16SZRFrom09-1995Till07-2003Part No.TypeCommentsFitmentUniversal Part No.
    12917Coil and ModuleCoil with module Distributorless
    18764Crankshaft Sensor
    18835Crankshaft Sensor
    14901EGR Valve
    14215Electric Valve10/95-04/02
    58900Flasher Unit
    14800Idle Control Valve
    83081Ignition Lead Set
    16800MAP Sensor
    16329Oxygen Sensor1 wire Precat16331
    50465Radiator Fan SwitchA/C
    50498Radiator Fan SwitchA/C
    49190sRotor ArmBosch/Valeo
    75011Thermostat
    19909Throttle Position SensorSPI
    #ff0000
    #ff0000
    #ff0000
    ManufacturerOPELModelVectraStroke cc1598Kilowatts55Fuel TypePetrolNumber Of Cylinders4Engine TypeSOHC/OHCEngine CodeC16NZ2From08-1992Till11-1995Part No.TypeCommentsFitmentUniversal Part No.
    44850Distributor CapKAT Delco
    44850Distributor CapDelco
    45772Distributor CapBosch/Valeo
    14900EGR Valve12/93->
    55523Engine Management Temperature Sensoroil temp. sensor
    58900Flasher Unit
    31538Fuel Pump
    12203Ignition CoilC16NZ2 Ducellier Ignition
    12626Ignition CoilKAT Delco
    12626Ignition CoilX16SZ Del system
    76332Ignition Lead Set>>Engine No 02N52986SAE
    76333Ignition Lead SetChassis No R100001,R5000001,R7500001>>SAE
    73866Ignition Lead SetWithout Heat Shields - With Coil LeadM4
    73976Ignition Lead SetEngine No 02N52987>>SAE
    15230Ignition ModuleKAT Delco
    15440Ignition ModuleDucellier Ignition
    15883Ignition Module88-92
    16800MAP Sensor
    14012Pickup CoilKAT Delco
    14012Pickup CoilX16SZ Del system
    50188Radiator Fan SwitchA/F Size 29 M22 x 1.5 T° 120-115/105-100
    50193Radiator Fan SwitchA/F Size 29 M22 x 1.5 T° 100-95
    50196Radiator Fan SwitchA/F Size 29 M22 x 1.5 T° 100-95
    50228Radiator Fan SwitchA/C
    47861Rotor ArmKAT Delco
    47861Rotor ArmDelco
    75011Thermostat
    75239Thermostat
    #ff0000
    الصورة الرمزية ashourashour
    رقم العضوية : 21515
    الاقامة : القاهره
    السيارة: .
    السيارة[2]: vectra c 2008 HL
    دراجة بخارية: .
    الحالة : ashourashour غير متواجد حالياً
    عفوا الاوبل ال 2000 سي سي الايكوتك بتاعت منصور مش بتنزل بموتور x20xev !!!!! دا موتور متسقط !!!!
    موتورها C20 الشهير !
    احمد عاشور
    لا تنسونا من صالح دعائكم
    المواتير المضافه
    Engine Code X20XEV
    C20SEL
    X16XEL
    X16SZR
    C16NZ2
    ولو عايز لماتور اخر انا تحت امرك
    الصورة الرمزية amr elsisi
    رقم العضوية : 131302
    الاقامة : الاسكندرية
    السيارة: اوبل فيكترا
    السيارة[2]: لانوس
    الحالة : amr elsisi غير متواجد حالياً
    2000 سي سي كامة واحدة اوتو
    السيارة[2]: لانوس
    الصورة الرمزية hamdy916
    رقم العضوية : 3028
    النوع : انثى
    السيارة: 85245537251
    السيارة[2]: Opel Vectra 98 1600
    دراجة بخارية: CharlesBoazy
    الحالة : hamdy916 غير متواجد حالياً
    مش فاهم اى حاجه ياريت شرح
    كل قطع غيار ليها رقم عالمى من جي ام و الشركات الاخري علشان ميحصلش لغبطه
    الصورة الرمزية Moabany
    رقم العضوية : 77538
    الاقامة : 6 اكتوبر
    السيارة: -
    السيارة[2]: فيكترا ايه 94 - 1600cc
    دراجة بخارية: -
    الحالة : Moabany غير متواجد حالياً
    اقتباس المشاركة الأصلية كتبت بواسطة kornclub مشاهدة المشاركة
    يا ريت فيكترا اية كمان
    مع الشكر
    والله المـوفــق
    م/ محمــد فــاروق
    ماتور ايه اللى حضرتك عايزه؟
    رقم العضوية : 77538
    الاقامة : 6 اكتوبر
    السيارة: -
    دراجة بخارية: -
    1600 سي سي
    متهيألي الكود بتاعة
    c 16 nz
    الموتور الفضي كامة واحدة
    وشكرا
    والله المـوفــق
    م/ محمــد فــاروق
  1. معلومات تهمك ,,,, حصريا
    بواسطة _hema في المنتدى نيـــــــــسان
    مشاركات: 14
    آخر مشاركة: 31-01-2012, 10:48 PM
  2. معلومات تهمك عن أحماء (تسخين) السيارة
    بواسطة Samir Elshahawy في المنتدى أخبار السيارات في مصر والعالم
    آخر مشاركة: 12-10-2011, 12:01 PM
  3. معلومات تهمك عن أحماء (تسخين) السيارة
    بواسطة Samir Elshahawy في المنتدى القــــسم التعلــــيمى
    مشاركات: 13
    آخر مشاركة: 12-10-2011, 08:52 AM
  4. معلومات طبية غريبة تهمك
    بواسطة mohamed_rhem في المنتدى عيــادة نايـل مـوتـورز
    آخر مشاركة: 08-12-2009, 12:37 PM
