All started the first day i received the car. I thought by time and تليين all will be fine but everything was the same till an error appeared related to the fuel system. I went to Nasr City and after check up, the engineer told me that either the fuel system, air intake system or the exhaust system is not working properly and that i have to go to el Haram center to solve it. At El Haram center, the engineer told me that my problem is the fuel itself.
What i also noticed that the fuel consumption when the car is not performing well is higher than usual and excessive heat comes from the ventilation system. Moreover, the milages to come reader depending on available fuel is not giving constant reading.
Upon fueling supposedly it reads 500km, if i stopped the car and restarted it, it might either read a higher or a lower km. That's all while not moving or even using air condition.
Any ideas ?
Thank You
