أسف على التكرار نتيجه وجود عيب بالسرفر......برجاء من المشرفين حذف المشاركات المكرره مع الشكر.......
رقم العضوية : 30705
الاقامة : Alexandria-Egypt
السيارة: Clio 1400cc
السيارة[2]: FLUENCE II-2014
لو حضرتك قبل الشراء كنت قريت عن اللوجان فى الانترنت كنت هتلاقى كل المعلومات اللى انت عايزها و اكتر و كنت هتقرا المميزات و العيوب اللى انت ساردها......المُصنع لم يخدع سيادتك أبدا و لا هو بايع مرسيدس بنز بسعر بسيط و كاتب عليها لوجان......اللى مشترى هذه السيارة لازم يبقى متأكد انه مشترى عربيه اقتصاديه جداً فى تصنيعها و نازله تخاطب شريحه معينه عايزه عربيه بسيطه مفهاش تكنولوجيا معقده و ديه ببساطه فكره إنتاج اللوجان.....عربيه تخاطب الشعب بسعر على قدها و برده مميزات و مواصفات على قدها...... يا ريت نقرا اللى جاى مع بعض
Designed at Renault's Technocentre near Paris, the Logan was the result of four years of development of the project X90, announced by Renault in 1999, after the buyout of Dacia in 1998.[1]
During a visit to Russia by French President Jacques Chirac, Louis Schweitzer noted that at Lada and Renault dealerships the €6,000 Ladas were selling very well while the €12,000 Renaults stayed in the showroom. "Seeing those antiquated cars, I found it unacceptable that technical progress should stop you making a good car for €6,000." (He later revised this target to €5,000). "I also drew up a list of specifications in three words – modern, reliable and affordable – and added that everything else was negotiable."[citation needed] The cheapest version of the car is €5,900, and the price can reach €11,200, depending on equipment and customs duty. (The base model for Western Europe, where it is badged as a Dacia but generally sold in Renault dealerships, is somewhat more expensive).
The Logan was designed from the outset as an affordable car, and has many simplified features to keep costs down. It replaces many older cars in production, including the Romanian Dacia 1310 series of Renault 12-based cars.
It was officially launched in September 2004. Renault originally had no plans to sell the Logan in Western Europe, but in June 2005, began importing a more expensive version of the car, starting at around €7,500.[2] It was an unexpected success with people wanting an inexpensive, no-frills car they could repair themselves.[citation needed]
العربيه نازله علشان تكون زى اللادا فى الانتشار و السعر......حاجات كتيره جداً متشاله منها أو منخفض سعرها بقوه و متقلل من جودتها علشان انزل بالسعر ده......عربيه لا يزيد تكلفه إنتاجها عن خمسه آلاف يورو.....فلسفه إنتاجها فى ٣ كلمات: حديثه، اعتمادية و اقتصاديه فى السعر.....تسويقها كان المفروض للدول النامية فقط اللى مش عايزين اختراعات فى عربياتهم....مجرد وسيله انتقال من نقطه A لنقطه B زى روسيا و الهند و مصر و المغرب و خلافه........
لو انا ببصلها من هذا المنظور value for money و فاهم انا بشتري ايه بفلوسى و ايه اللى منتظره من السياره هبقى سعيد جداً بهذه الصفقة الرابحه و كمان هحس أنى كسبان من هذه الصفقة....... لأنى ببساطه بسأل حضرتك لو مكنتش اشتريت اللوجان زى ما بتقول......كنت هتجيب ايه بنفس القيمه و الكماليات زيرو.....يا ريت تشاركنا بمميزات و عيوب اختيارك لو مكنش لوجان للاستفادة
لكن لو بصينا للوجان من منظور فئات سيارات اعلى و قعدنا نتكلم على ثبات فوق ال١٢٠ و صوت الموتور و العزل و خلافه يبقى أكيد احنا بنظلمها و بشده لان المقارنة ظالمه و دى مش الفئة بتاعتها للمقارنة.......
م/هانى سعد
Meggieboy سابقا
رقم العضوية : 30705
م/هانى سعد
Meggieboy سابقا
رقم العضوية : 101576
الاقامة : السعودية
السيارة: سيراتو ٢٠١٥A/T
السيارة[2]: 2012 logan B/L
8 مشاركات متكررة
رقم قياسى .......شد حيلك ..
ههههههههههههههههه
وقال فرعون ذرونى اقتل موسى وليدع ربه انى اخاف ان يبدل دينكم او ان يظهر فى الارض الفساد " يا سلام على ايمان وورع فرعون وفعلا صدقوه ....وبرده كانوا مصريين
رقم العضوية : 30705
The Logan is based on the B0 platform used for the Renault Clio II and for other Renault and Nissan models.[8] It has 50% fewer parts than a high-end Renault vehicle and has a limited number of electronic devices. This makes the car cheaper to produce and easier and cheaper to repair.
Some parts are also much simpler than those of its competitors. For example, rear-view mirrors are symmetrical and can be used on either side of the car, the windshield is flatter than usual, and the dashboard is a single injection-molded piece.
The developers have taken into account several differences between road and climate conditions in developed and developing countries. The Logan suspension is soft and strong, and the chassis sits visibly higher than most other compact cars to help it negotiate dirt roads and potholes on ill-maintained asphalt roads. The engine is specially prepared to handle lower quality fuel, whereas the air conditioning is powerful enough to lower the temperature several degrees (temperatures above 40 °C are common in the Middle East and the Mediterranean Sea).
م/هانى سعد
Meggieboy سابقا
رقم العضوية : 442
الاقامة : Egypt
السيارة: 127 & 128
السيارة[2]: Logan 2010 FO
دراجة بخارية: none
نفسى أفهم ايه المقصودة بالعبارة دى ..the engine is specially prepared to handle lower quality fuel
The only alternative to coexistence is codestruction - Nehru
رقم العضوية : 27012
الاقامة : CAIRO-ABUDHABI
السيارة: لوجان 2013 اوتو
السيارة[2]: نصر 128
دراجة بخارية: هوندااا
رقم العضوية : 60894
السيارة: pointer 2005 1.6
السيارة[2]: TOLEDO MK4
دراجة بخارية: none
رقم العضوية : 442
الاقامة : Egypt
السيارة: 127 & 128
دراجة بخارية: none
رقم العضوية : 42166
الاقامة : مدينة العبور
السيارة: لوجان
السيارة[2]: برايد سيدان
رقم العضوية : 30705
دلوقتى سعرها بقى أوفر طبعا ٩٠ الف و لازم الناس تدرس كويس ايه المتاح من المنافسين فى نفس الشريحة السعرية.....طبعا مع الوضع فى الحسبان زياده أسعار جميع السيارات.....مثلا الكيا بيكانتو سعرها وصل ١٠٠ ألف جنيه و ده على سبيل المثال و ليس الحصر......لكن اول ما اللوجان نزلت و كانت فى رينج ٦٠ و ٧٠ ألف اعتقد كانت تعتبر الحصان الأسود فى السوق بالنسبة لهذه الشريحة السعريه........
م/هانى سعد
Meggieboy سابقا
