رقم العضوية : 57
الاقامة : مدينة نصر
السيارة: هيونداي فيرنا
السيارة[2]: هيونداي فيرنا
دراجة بخارية: -
5DR Hatch L 5DR Hatch LS 5DR Hatch LT
ENGINE
Type 3 Cyl Transverse 4 Cyl Transverse 4 Cyl Transverse
Valves s-o-h-c,6v s-o-h-c,8v s-o-h-c,8v
Capacity cm3 795 995 995
Power (Kw at r/min) 38/ 5900 48.5/ 5400 48.5/ 5400
Torque (Nm at r/min) 68.6/ 4600 87.3/ 4200 87.3/ 4200
Fuel Supply Multipoint injection Multipoint injection Multipoint injection
Fuel requirement Unleaded Unleaded Unleaded
Emission control system Siemens EMS Siemens EMS Siemens EMS
TRANSMISSION
Type 5 Speed Manual 5 Speed Manual 5 Speed Manual
Gear Ratios:
First 3.818 3.416 3.416
Second 2.21 1.950 1.950
Third 1.423 1.280 1.280
Fourth 1.029 0.971 0.971
Fifth 0.837 0.757 0.757
Reverse 3.583 3.272 3.272
Final drive ratio 4.444 4.444 4.444
CHASSIS/SUSPENSION
Front Suspension McPherson Strut McPherson Strut McPherson Strut
Rear Suspension Compound Link Type Compound Link Type Compound Link Type
STEERING
Power assisted
Standard
Type Rack & pinion Rack & pinion Rack & pinion
Turning Circle: Wall to Wall(m) 4.68 4.68 4.68
BRAKES
Front Disc Solid Disc Solid Disc Solid
Rear Drum Drum Drum
WHEELS & TYRES
Wheel Size 4.5J x 13 4.5J x 13 4.5J x 13
Type Steel Alloy Alloy
Tyre size 145/70 R13 155/65 R13 155/65 R13
Full size spare wheel Standard Standard Standard
DIMENSIONS
Exterior:
Wheelbase (mm) 2345 2345 2345
Length (mm) 3495 3495 3495
Width (mm) 1495 1495 1495
Height (mm) 1500 1500 1500
Interior:
Seating capacity 5 5 5
Head room front/rear 1004/959 1004/959 1004/959
Legroom front/rear 1022/900 1022/900 1022/900
Shoulder room front/rear 1250/1250 1250/1250 1250/1250
Hip room front/rear 1244/1242 1244/1242 1244/1242
Kerb weight (kg) 795 830 850
This is the one that we have here in Egypt:
995 Liter engine—SOHC 4 CYL 8 valve
Fuel System: Multi point injection
Maximum Power (65 hp / 5400 rpm)
Maximum Torque (91 N.m / 4200 rpm)
Manual 5 speed transmission
Fuel economy 4.7 liter/1000 km (non urban), 7.2 litre/1000 km (urban), 5.6 litre[hr:441c8f8fb9]/1000 km (total)
Length (mm) 3459, width (mm) 1495, height (mm)1500
Power Steering
A/C
Radio Cassette+2 speakers
In addition to other options
رقم العضوية : 44
الاقامة : الرحاب- القاهرة
السيارة: Suzuki Jimny 2009, PT Cruiser 2005
السيارة[2]: Pajero NM 2001
:) حازم حـزه :)
رقم العضوية : 101
الاقامة : tanta & alex
السيارة: ربنا يرزق
السيارة[2]: optra at 2007
ايه ده هى نازله بحساسات ركن :shock: :shock: :shock:
hoko_mosha سابقا
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
لآ طبعاًايه ده هى نازله بحساسات ركن
لأي استفسار أو شكوى بخصوص الإدارة والإشراف والدعم الفني، يرجى المراسلة على:
رقم العضوية : 101
السيارة: ربنا يرزق
امال ايه اللى فى الاكصدامات اللى فى الصوره الثالثة فى صور استاذ حازم
hoko_mosha سابقا
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
ايوة باركينج سنسور بس طبعاً مش موجود هنا في مصر
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
دي صور تانية
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
وصور كمان
هنا مفيش باركينج سنسورز
رقم العضوية : 1122
الاقامة : egypt
السيارة: Lada , 2 Terios , 3 Cerato
السيارة[2]: COROLLA 2014
يعنى انت متوقع مصر ينزل فيها سينسور
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
لأ دول لو يطولوا هينزلوها من غير اكصدام خالص :mrgreen:
