[2007 Jeep Compass
Year 2007
Make Jeep
Model Compass
Engine Location Front
Drive Type Front Wheel (standard), 4WD
Production Years for Series 2007 -
Price MSRP: $15,425.00
Invoice: $14,537.00
Weight 3155 lbs | 1431.1 kg
Introduced At 2002 Detroit MI
Engine
Engine Configuration I
Cylinders 4
Aspiration/Induction Normal
Displacement 2.40 L | 146.4 cu in. | 2399.5 cc.
Valves 16 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 172.00 HP (126.6 KW) @ 6000.00 RPM
Torque 165.00 Ft-Lbs (223.7 NM) @ 4500.00 RPM
HP to Weight Ratio 18.3 LB / HP (Vehicles with similar ratio)
HP / Liter 71.7 BHP / Liter
Redline 6500
Bore 3.46 in | 87.9 mm.
Stroke 3.82 in | 97 mm.
Compression Ratio 10.5:1
Fuel Type Gasoline - Petrol
Fuel Feed Fuel Injected
Electronic Sequential Port Fuel Injection
Block Cast-Aluminum
Head Cast-Aluminum
Vehicles with similar horsepower and weight
Gear Ratios
1st Gear 3.77
2nd Gear 2.16
3rd Gear 1.41
4th Gear 1.026
5th Gear 0.81
Standard Transmission
Gears 5
Transmission Manual
Magna Driveline T355
Final Drive 4.12
Optional Transmission
Transmission CVT
Automatic, Jatco Model CVT2
Final Drive 6.12:1
Dimensions
Cargo Volume 53.60 cu. ft.
Passenger Volume 101.301 cu. ft.
Towing Capacity 2000.001 lbs
Standard Payload 925.001 lbs
Fuel Capacity 13.6 Gal
Seating Capacity 5
Doors 4
Exterior
Length 173.401 in | 4404.4 mm.
Width 71.301 in | 1811 mm.
Height 65.201 in | 1656.1 mm.
Wheelbase 103.701 in | 2634 mm.
Front Track 59.801 in | 1518.9 mm.
Rear Track 59.801 in | 1518.9 mm.
Ground Clearance 8.401 in | 213.4 mm.
Front Overhang 34.51 in | 876.6 mm.
Rear Overhang 35.21 in | 894.3 mm.
Interior
Front Headroom 40.701 in | 1033.8 mm.
Rear Headroom 39.901 in | 1013.5 mm.
Front Legroom 40.601 in | 1031.3 mm.
Rear Legroom 39.401 in | 1000.8 mm.
Front Hip Room 52.31 in | 1328.7 mm.
Rear Hip Room 51.01 in | 1295.7 mm.
Front Shoulder Room 54.601 in | 1386.9 mm.
Rear Shoulder Room 54.001 in | 1371.6 mm.
Vehicles with similar dimensions
Suspension
Suspension Front : Independent MacPherson strut, coil spring over gas-charged shock absorbers and stabilizer bar
Rear : Multi-link independent with coil springs, link-type stabilizer bar, gas-charged shock absorbers
Steering
Rack and Pinion
Steering Overall Ratio 16.4:1
Turns lock to lock 2.88
Turning Circle 35.601 ft
Brakes
Front Brakes Disc
Rear Brakes Disc
Front Brake Size 11.501 in | 292.1 mm.
Rear Brake Size 10.301 in | 261.6 mm.
Tires / Wheels
Tires P215/60R17 BSW AS Touring Firestone Affinity S3
Wheels 17-inch aluminum wheels
Spare Tire Compact
