رقم العضوية : 57
الاقامة : مدينة نصر
السيارة: هيونداي فيرنا
السيارة[2]: هيونداي فيرنا
دراجة بخارية: -
[2007 Jeep Compass
Year 2007
Make Jeep
Model Compass
Engine Location Front
Drive Type Front Wheel (standard), 4WD
Production Years for Series 2007 -
Price MSRP: $15,425.00
Invoice: $14,537.00
Weight 3155 lbs | 1431.1 kg
Introduced At 2002 Detroit MI
Engine
Engine Configuration I
Cylinders 4
Aspiration/Induction Normal
Displacement 2.40 L | 146.4 cu in. | 2399.5 cc.
Valves 16 valves.
4 valves per cylinder.
Valvetrain DOHC
Horsepower 172.00 HP (126.6 KW) @ 6000.00 RPM
Torque 165.00 Ft-Lbs (223.7 NM) @ 4500.00 RPM
HP to Weight Ratio 18.3 LB / HP (Vehicles with similar ratio)
HP / Liter 71.7 BHP / Liter
Redline 6500
Bore 3.46 in | 87.9 mm.
Stroke 3.82 in | 97 mm.
Compression Ratio 10.5:1
Fuel Type Gasoline - Petrol
Fuel Feed Fuel Injected
Electronic Sequential Port Fuel Injection
Block Cast-Aluminum
Head Cast-Aluminum
Vehicles with similar horsepower and weight
Gear Ratios
1st Gear 3.77
2nd Gear 2.16
3rd Gear 1.41
4th Gear 1.026
5th Gear 0.81
Standard Transmission
Gears 5
Transmission Manual
Magna Driveline T355
Final Drive 4.12
Optional Transmission
Transmission CVT
Automatic, Jatco Model CVT2
Final Drive 6.12:1
Dimensions
Cargo Volume 53.60 cu. ft.
Passenger Volume 101.301 cu. ft.
Towing Capacity 2000.001 lbs
Standard Payload 925.001 lbs
Fuel Capacity 13.6 Gal
Seating Capacity 5
Doors 4
Exterior
Length 173.401 in | 4404.4 mm.
Width 71.301 in | 1811 mm.
Height 65.201 in | 1656.1 mm.
Wheelbase 103.701 in | 2634 mm.
Front Track 59.801 in | 1518.9 mm.
Rear Track 59.801 in | 1518.9 mm.
Ground Clearance 8.401 in | 213.4 mm.
Front Overhang 34.51 in | 876.6 mm.
Rear Overhang 35.21 in | 894.3 mm.
Interior
Front Headroom 40.701 in | 1033.8 mm.
Rear Headroom 39.901 in | 1013.5 mm.
Front Legroom 40.601 in | 1031.3 mm.
Rear Legroom 39.401 in | 1000.8 mm.
Front Hip Room 52.31 in | 1328.7 mm.
Rear Hip Room 51.01 in | 1295.7 mm.
Front Shoulder Room 54.601 in | 1386.9 mm.
Rear Shoulder Room 54.001 in | 1371.6 mm.
Vehicles with similar dimensions
Suspension
Suspension Front : Independent MacPherson strut, coil spring over gas-charged shock absorbers and stabilizer bar
Rear : Multi-link independent with coil springs, link-type stabilizer bar, gas-charged shock absorbers
Steering
Rack and Pinion
Steering Overall Ratio 16.4:1
Turns lock to lock 2.88
Turning Circle 35.601 ft
Brakes
Front Brakes Disc
Rear Brakes Disc
Front Brake Size 11.501 in | 292.1 mm.
Rear Brake Size 10.301 in | 261.6 mm.
Tires / Wheels
Tires P215/60R17 BSW AS Touring Firestone Affinity S3
Wheels 17-inch aluminum wheels
Spare Tire Compact
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
رقم العضوية : 101
الاقامة : tanta & alex
السيارة: ربنا يرزق
السيارة[2]: optra at 2007
ربنا يوعدنا يا استاذ نادر شكرا على الصور بس اخدت بالك من السعر :D :D
hoko_mosha سابقا
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
يا راب، طبعلً مجدتش بالي من السعر ومش عاوز اخد بالي منة، مش ناقصة وجع قلب :)ربنا يوعدنا يا استاذ نادر شكرا على الصور بس اخدت بالك من السعر
لأي استفسار أو شكوى بخصوص الإدارة والإشراف والدعم الفني، يرجى المراسلة على:
رقم العضوية : 2087
الاقامة : Nasr City, Cairo
السيارة: ميتسوبيشي لانسر 2006
السيارة[2]: شيفرولية فرونتيرا 3200 V6 (ايسوزو روديو)
شكلها من ورا حلو بس وشها قبيح قوي وبالذات الاكصدام شكلة غبي جدا بالجناب اللي طالعه منة مع الدورانات دي
وتابلوهها مش شيك بتاتا بس امكانياتها عالية جدا
ربنا يوعدنا و يوعدكم
رقم العضوية : 475
الاقامة : الأسكندرية
السيارة: I30 & Megane estate
السيارة[2]: E36 Coupe 328i
دراجة بخارية: .
شكرا يا نادر جامدة والله
بس هوة اية CVT 2 دة اية الفرق بينة و بين ال CvT العادى
رقم العضوية : 2823
الاقامة : مصر القديمة القاهرة
[quote="Adham"]شكلها من ورا حلو بس وشها قبيح قوي وبالذات الاكصدام شكلة غبي جدا بالجناب اللي طالعه منة مع الدورانات دي
ربنا يوعدنا و يوعدكم[/quot
approved ;)
best regards
http://img107.mytextgraphics.com/pho...n-f8v6xu8n.jpg
eng - bashar elshamy
رقم العضوية : 37
الاقامة : الاسكندرية
السيارة: Fiat Brava
السيارة[2]: Honda City 1.5
دراجة بخارية: None
المشاركة الأصلية كتبت بواسطة Adham
يا سيدى قبيح قبيح مش مشكلة بس اديهالى بالسعر دة :)
حاجة و الله تشل لما تشوف احنا بيتنصب علينا فى مصر علنياً كدة م نالحكومة و التجار و التوكيلات ... !! لأ و كمان كاتبلك الـ invoice price عشان تعرف تفاصل مع المعرض و انت عارف العربية واقفة عليه بكام ... ايه العالم المرفهة دى؟!!!
الَّذِينَ آمَنُوا وَتَطْمَئِنُّ قُلُوبُهُمْ بِذِكْرِ اللَّهِ أَلا بِذِكْرِ اللَّهِ تَطْمَئِنُّ الْقُلُوبُ
