1. Streamlined sophisticated styling
The exterior design of the new Tribeca is streamlined and powerful,
building upon the sporty and dynamic feel of its predecessor model.
Interior designs express a sophisticated quality look and sportiness.
2. Outstanding performance
The new Tribeca has been developed with the goal of balancing
improved performance and environmental considerations.
Without increasing the physical dimensions of the power unit,
the displacement was expanded from 3.0 to 3.6 liters, which was
made possible primarily through design changes involving expanded
bore dimensions and a longer stroke.
The new engine maintains the same levels of emissions and fuel
efficiency as the previous 3-liter unit, despite the larger engine
size and more powerful output.
The new 3.6-liter boxer engine features Dual Active Valve Control
System (Dual AVCS) for controlling timing in both the intake and
exhaust valves, which helps provide improved low-end torque.
Design modifications made to the cooling system allow the use of
regular unleaded gasoline, which contributes to lowering consumer
operating costs.
A substantially revised 5-speed Automatic transmission with newly
designed control unit, refined torque converter and optimized gear
ratio delivers faster shifting response and smooth and powerful acceleration.
The new engine and transmission are lighter weight, achieving a total weight
reduction of 4.4 kilograms.
3. Improved comfort and functionality
The new Tribeca offers a pleasant ride with improved access, visibility, and
comfort.
Third row seating access has been enhanced through a number of changes.
The second row seat comes with a tilt-and-slide control on both the driver`s
and passenger`s sides and a new assist spring that reduces the effort needed
to slide the second row seat. Also new are molded grab handles on the lower
C-pillar to assist in stepping into the third row.
With redesigned door mirrors and rear quarter windows, side and rear vision
have been improved.
Re-calibrated rear suspension with new bushings improves ride comfort
http://www.blogsmithmedia.com/www.au...6/dsc_0006.jpg
http://www.blogsmithmedia.com/www.au...6/dsc_0009.jpg
http://www.blogsmithmedia.com/www.au...6/dsc_0027.jpg
