رقم العضوية : 57
الاقامة : مدينة نصر
السيارة: هيونداي فيرنا
السيارة[2]: هيونداي فيرنا
دراجة بخارية: -
1. Streamlined sophisticated styling
The exterior design of the new Tribeca is streamlined and powerful,
building upon the sporty and dynamic feel of its predecessor model.
Interior designs express a sophisticated quality look and sportiness.
2. Outstanding performance
The new Tribeca has been developed with the goal of balancing
improved performance and environmental considerations.
Without increasing the physical dimensions of the power unit,
the displacement was expanded from 3.0 to 3.6 liters, which was
made possible primarily through design changes involving expanded
bore dimensions and a longer stroke.
The new engine maintains the same levels of emissions and fuel
efficiency as the previous 3-liter unit, despite the larger engine
size and more powerful output.
The new 3.6-liter boxer engine features Dual Active Valve Control
System (Dual AVCS) for controlling timing in both the intake and
exhaust valves, which helps provide improved low-end torque.
Design modifications made to the cooling system allow the use of
regular unleaded gasoline, which contributes to lowering consumer
operating costs.
A substantially revised 5-speed Automatic transmission with newly
designed control unit, refined torque converter and optimized gear
ratio delivers faster shifting response and smooth and powerful acceleration.
The new engine and transmission are lighter weight, achieving a total weight
reduction of 4.4 kilograms.
3. Improved comfort and functionality
The new Tribeca offers a pleasant ride with improved access, visibility, and
comfort.
Third row seating access has been enhanced through a number of changes.
The second row seat comes with a tilt-and-slide control on both the driver`s
and passenger`s sides and a new assist spring that reduces the effort needed
to slide the second row seat. Also new are molded grab handles on the lower
C-pillar to assist in stepping into the third row.
With redesigned door mirrors and rear quarter windows, side and rear vision
have been improved.
Re-calibrated rear suspension with new bushings improves ride comfort
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
رقم العضوية : 388
الاقامة : Port Said
السيارة: N/A
السيارة[2]: BMW 330i
دراجة بخارية: N/A
عربيه تحفه.. و مكسره الدنيا في امريكا (وعلى فكره هيه بتتصنع هناك)
Thanks
Ahmed Hassan
When all you have is a hammer, everything looks like a nail
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
بس للاسف صعب نشفها هنا في مصر
رقم العضوية : 388
الاقامة : Port Said
السيارة: N/A
دراجة بخارية: N/A
اخرنا في مصر الـ FORESTER
Thanks
Ahmed Hassan
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
ايوة بيتمنظر بيها "علية القوم" :Dاخرنا في مصر الـ FORESTER
لأي استفسار أو شكوى بخصوص الإدارة والإشراف والدعم الفني، يرجى المراسلة على:
رقم العضوية : 475
الاقامة : الأسكندرية
السيارة: I30 & Megane estate
السيارة[2]: E36 Coupe 328i
دراجة بخارية: .
الف شكر على الموضوع الجميل دة
و فعلا انا من اكتر الشركات الى بحبها فى السيارت هيا السوبارو بعد ال BMW :)
بس لو انا فى مصر نفسى :) :) و يارب تتحقق و اجيب سوبارو امبريزا WRX STI شفت انا طماع ازاى :) :) مش حتى RX ههههههههههه
ان شاء الله يتحقق و نفسى فى موديل 2007 مش 2008 :) بصراحة بحب اوى شكل 2007 و حاسس انو احسن شكل للأمبريزا
رقم العضوية : 388
الاقامة : Port Said
السيارة: N/A
دراجة بخارية: N/A
ربنا يسمع منك يا فهد... بس في التوكيل قالولي ان آخرنا WRX و بالفعل فيه واحده في مصر و بيقولوا فيه واحده تانيه نازله. بالنسبه للـ STI فبيقولوا مش هاتنزل لأنها بتشتغل ببنزين 98 :mrgreen:
Thanks
Ahmed Hassan
رقم العضوية : 475
دراجة بخارية: .
98 :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock: :shock:
لا لا لا لا و مالها ال WRX جمييييييييييلة جدا هههههههههه
بس متعرفش حاجة عن سعر ال WRX ؟؟؟؟؟؟
و شكرا ليك
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
ربنا يرزق يا سيدي 8)بس لو انا فى مصر نفسى و يارب تتحقق و اجيب سوبارو امبريزا WRX STI شفت انا طماع ازاى مش حتى RX ههههههههههه
ان شاء الله يتحقق و نفسى فى موديل 2007 مش 2008 بصراحة بحب اوى شكل 2007 و حاسس انو احسن شكل للأمبريزا
