الصناعة كندا ودى الامكانيات ياترى يعمل كام عشان فى صديق محتاجة وان مش عارف السعر
Power Source : DC 14V
Channels : 2
Mode : A1
Out Power (4 Ohm) : 2x200
(2 Ohm) : 2x380
Bridge (4 Ohm) : 1x760
Signal-to-noise : >100 dB
THD+noise@Rated : 0.1 %
Frequency Respons : 10~30000
Bandwidth : 15K~50K
Channel Separation : 96 dB
Damping Factor : >200
Input Sensitivity : 0.2~7V
Input Impedance : 15K
Input ModeRem/Loc : N/A
High Pass Crossoer : 15~200Hz
Low Pass Crossover : 30~500Hz
Sub Frequency : N/A
Bass EQ Booster : 0~18dB
Filter Slop (LPF) : 24 dB
Cooling Fan Souce : Option
TwinPowerSupplies : Twin
Indicator LED : Pow(Blue) - One , Prot(Red) - One
Protection : Thermal
Power Consumption : Idle - 0.9A , Max - 62A , Remote - 0.26A
Dimension : Width - 250(m/m) , Height - 58(m/m) , Depth - 400(m/m)
Weight : 5.6Kg
