ﺷﻜﺮﺍ ﻳﺎﺑﺎﺷﺎ ﻋﻠﻲ ﺍﻟﺮﺩ ﺍﻟﺴﺮﻳﻊ
ﻋﺸﺎﻥ ﻋﻨﻲ ﺍﻟﻤﻜﻨﻪ ﺑﺘﺘﺮﻋﺶ ﻋﻠﻲ ﻃﻮﻝ ﻭﺑﺘﻨﺘﺶ ﻓﻲ ﺍﻭﻝ ﺍﻟﻐﻴﺎﺭ ﺍﻟﺘﺎﻧﻲ ﻭﺍﻟﺘﺎﻟﺖ ﻟﻤﺎ ﺍﻛﺒﺲ ﺑﻨﺰﻳﻦ
ﻋﻤﻠﺖ ﺍﺳﻜﺎﻥ ﻣﻘﺮﺍﺵ ﻋﻂﻞ
ﺍﻟﻜﻬﺮﺑﺎﻱ ﺧﺮﺝ ﺍﻟﺤﺴﺎﺱ ﺑﺮﻩ
ﻭﻓﺘﺤﺖ ﺍﻟﻜﻮﻧﺘﺎﻛﺖ ﻗﻠﻲ ﺍﻟﻤﻔﺮﻭﺽ ﻳﺘﺤﺮﻙ كده الحساس جاب اخره هغير وتشوف النتيجهﻣﻊﺍﻟﻜﻮﻧﺘﺎﻛﺖﻩ ﺟﺎﺏ ﺍﺧﺮﻩ
filter oil MANN W68 / 1; MAHLE (Knecht) OC216, etc.
Fuel filter Nipparts J1332024; FILTRON PP895, etc.
Air filter FILTRON - AR 125
Candles Denso K16R-U, K16-TT
washer to adjust the thermal backlashes in valves diameter 28mm. Toyota Carina, Avensis, King, Selick.
Timing Belt 1) 117MY21. 2) CT 827 117Z (corolla 1.6 08/89 - 04/92)
alternator belt 1987947918
Belt conditioner -1987947894
Belt GUR -3PK-515
roller-tensioner timing belt rollers LuK 531018120
roller-conditioner belt tensioner roller bearing : 6203 (ball bearings, single row, indoors).
perёd brake pads car with ABS-36658
anthers guides 113-1321 caliper
brake pads rear ABS 04495-87704-000
FRONT hodovka:
-tyaga Tie - 45503-87708-000 and left and right (the same)
-Salniki In rail Otaka, Kit:
-Emmetec GL 9001 KIT + this one gland 19h35h6 goes to the steering rack Nissan Blyubird. Code 49265-6N000
-stoechki front staba- Sidem 5663 and 5662 Sidem These racks are left to the right side and the right to his left. In Reno, they are not set in Otake.
-Tormoznye Wheels perёd -
ROADHOUSE 6363.00
BREMBO 08.5878.10
- Support for the front rack itself is also code for Sasic 0385235
Silent large rear lever (front)
right-J40504COEM,
left- J40504BOEM
Silent small front lever (front)
54551-22000
Hyundai / KIA 54571 22000 - bracket holding back Hob front lever (ie, large)
-Stupichny Bearing perёd- 90043-63214
ball joint - CI-BJ-3354
-nakonechniki rulevye- 45046-87782-000 right
-Nakonechnik steering - 45047-87782-000 left
-resistant:
1.-The easiest option, repack the rack!
2. The cartridge rack (if remodel a collapsible)
Caiabu 664,014 (golfovsky liner front)
If modifications are necessary to build a glass rack and steal the course of breakdown of 4-5 cm., so it is advisable to supplement the alteration stiffer springs.
3.-amo perёd Absorber KYB 333506 from Hyundai Getz-F®
Absorber KYB 333507 from Hyundai Getz-F (L).
It is the right and left of the rack. Series racks KYB Excel G
Racks melts with no significant modifications + expedient perfect balance with the more rigid springs so to have hyundaevskih racks considerably less progress in the probe.
-pruzhiny racks before: Monroe SP2505;
-vtulka stabilizer front - HONDA CIVIC since 1996. 51306S04N01
-Otboynik Front Amica with anther
-SACHS (900001)
bearing upper support: Lemforder 31405 01 (405, Citroen Ksara, RenoLaguna)
BACK hodovka:
-Rear small stands stub Toyota Land Cruiser 100, 48820-60032
-opora under the rear rack - support hyundaya emphasis (on that rack fits)
analogs silent blocks zadnіh transverse richagіv.
I give їhnі Cody: 52773-25000 - tse Hob s Malimo opened
i opened the GRAND de robitsya rozval HYAB-AC219, 55219-25100, JK5-516MP. Tsі saylentbloki od Hyundaya Accent Year 1999-2006. Located on the same mashinі de i nashі.
Also od tsogo Well Hyundaya pіdhodyat sleeve reactive rod-5511925000
-podshipniki rear tapered rear hub 713 6102 40 (set)
Racks:
-1.PEREPAkovat rack!
-2.Kartridzhi rack (if remodel a collapsible)
It is desirable to perfect balance with the installation of a hard and short springs!
-3.Stoyka back (Hyundai accent 99-2006 s) Geely CK: KYB332109 - left, KYB332108 - right, set, but only one - should be the hub on both sides by 1.75mm cut down as well, one to one.
-pruzhiny racks ass: Monroe SP2498.
The trailing arm rear bushing sleeve = rear shock VAZ2108 № 2108-2915446-01.
-vtulka rear stabilizer - HONDA CIVIC since 1995.
52315-SK3-010
-Tormoznoy Rear cylinder (with ABS) Geely CK (Toyota) 3502135005/3502140005
Kit brake cylinder rear Seinsa D3164-19mm Seinsa D3415-17,5mm
ELECTRICITY:
- bearing genes = Bearing Similar Containers of genes Deviatiny.
-shokoladka and brushes geny- 94323702 (one block)
diodes bought 5 UAH on the radio. common.
-Schёtochny Starter unit, one to one from 2110
-Bosch 0580454001-fuel pump.
-ALT5041- Analogue of genes for MC and SC
Seeing-vysokovoltnye- 90998-99002, TSN 1.4.30 (thick, excellent quality)
-analog Retractor on the starter checked personally, relays, one to one from 2110, the difference in the mounting holes, we have 2 pieces. in vazovskaya 4pcs. Manufacturer Manufacturer - "Electron"
Zapalennya module "(Bosch № 0221 503 465 is the number on the module)
-Benzonasos with pelvic tithe
-Motorchik Washer From Lanos
-sensors throttle position From the "Volga" GAZ 3110: Bosch 0280122001.
-regulators idle hoda- Chery Amulet
CAT S160
Bearings
NSK 6208-100gr
NSK 6305 (2 pieces) -85gr
30204-80gr NSK
NSK 32006-120gr
SKS 6308-165gr
-Soldatik Fork of the stage 2101-1601215
-Vyzhimnoy bearing on the Yaris 99-02 years vypuska.odin one. such a
BT-021
-pylnik fork stsepy- 31126-12051
OTHER:
incubator toyotovskih 82 degrees = 90916-03046
90916-03063 = 88 Degrees
-pruzhinka in the scenes to secure the stick-mixer - 90508 -20084 existu on its way as a gasket :), but it is spring!
-rezinki suspension exhaust system - from Lanos
-Podshipnik pump GUR 6303
-motorchik pisyalki- with Lanos
-remkomplekt master cylinder
D1292
-krestoviny steering shaft = cross steering shaft from the WHA 2105
Dvigalishko:
The Chinese in dull copied Toyota 5a-fe, stuck DIS2 ignition system and strangled him in the euro 4
References on sites do Thun zips for Otaka and selling analogues of production is not China!
geelygroup.prom.ua/g45236...-zapchasti-evropy-yaponii
a-tuning.net/pu/geely/ck.htm
شكرا يا حبيبى على هذه المعلومات الجميلة والحقيقة اذا توافرت قطع الغيار الجيدة فان هذه العربية جميلة ..ولك جزيل الشكرا
انا اشتريت تيل فرامل امامى اسبرنزا a620
75 جنية وركبتهم والحمد لله تمام
