b16b
FEEL THE VTEC
https://www.youtube.com/watch?v=MsY93zBzEvo
Displacement: 1,595 cc (97.3 cu in)
Compression: 10.8:1
Bore: 81 mm (3.2 in)
Stroke: 77.4 mm (3.0 in)
Rod/Stroke ratio: 1.84:1
Rod Length: 142.42 mm (5.6 in)
Power: 187 hp (139 kW) @ 8200 rpm & 118 lb·ft (160 N·m) @ 7500 rpm
Redline: 8400 rpm
Rev-limit: 9000 rpm
Transmission:S4C With Helical LSD (4.4 final drive, dual-synchromesh on 2nd, 3rd and 4th gears)
VTEC engagement 6200 rpm
ECU code: PCT
ECU Socket Type: OBD-2A(1996-1998 models) / OBD-2B(1999-2000 models)
Note: This engine uses the same block as the Integra Type R (B18C5), which is taller than the B16a block (by approx 17 mm), but with a crank the same stroke as the b16a. It uses longer rods to accommodate for this, which is why the Rod/Stroke ratio is higher than a standard B16.
