النتائج 1 إلى 10 من 21
الموضوع: stunning 6th gen tuning
    الصورة الرمزية banzai
    رقم العضوية : 150353
    الاقامة : egypt
    السيارة: bugattk
    السيارة[2]: bugatti
    الحالة : banzai غير متواجد حالياً
    افتراضي stunning 6th gen tuning - Facebook Twitter whatsapp انشر الموضوع فى :
    بما انى من عشاق الجيل السادس فهضع هنا فيدز لتعديلات عليها ,موضوع متجدد
    1999 Honda Civic EK K20 K24 LSD S2000 S2K
    1999 Honda Civic EK K20 K24 LSD S2000 S2K - YouTube
    Motor:
    2009 tsx k24a2
    2006 rsx type s k20 head
    Ep3 civic type r tranny 6 speed
    Rbc manifold
    Hybrid racing k swap axles
    3 inch straight pipes to VIBRANT muffler
    150hp shot wet nitrous (not in video)
    Suspension:
    Skunk 2 springs
    Skunk 2 shocks
    Skunk 2 control arms
    Skunk 2 camber
    ASR subframe
    ASR Sway bar
    Full race traction bar
    Interior:
    Bride racing seats
    S2000 cluster
    Ek9 civic type r momo steering wheel
    Hybrid racing short throw shifter set up
    Pioneer DIN Radio
    Exterior:
    Stance mindsets 16x8
    Federal evo 195/40/16 tires
    Type r front lip
    Jdm side marker blinkers
    Black housing headlights
    Spoiler delete
    Emblem delete
    فَاتَّبَعُوا أَمْرَ فِرْعَوْنَ ۖ وَمَا أَمْرُ فِرْعَوْنَ بِرَشِيدٍ يَقْدُمُ قَوْمَهُ يَوْمَ الْقِيَامَةِ فَأَوْرَدَهُمُ النَّارَ ۖ وَبِئْسَ الْوِرْدُ الْمَوْرُودُ
    الاقامة : egypt
    السيارة: bugattk
    السيارة[2]: bugatti
    b16b
    FEEL THE VTEC
    https://www.youtube.com/watch?v=MsY93zBzEvo
    Displacement: 1,595 cc (97.3 cu in)
    Compression: 10.8:1
    Bore: 81 mm (3.2 in)
    Stroke: 77.4 mm (3.0 in)
    Rod/Stroke ratio: 1.84:1
    Rod Length: 142.42 mm (5.6 in)
    Power: 187 hp (139 kW) @ 8200 rpm & 118 lb·ft (160 N·m) @ 7500 rpm
    Redline: 8400 rpm
    Rev-limit: 9000 rpm
    Transmission:S4C With Helical LSD (4.4 final drive, dual-synchromesh on 2nd, 3rd and 4th gears)
    VTEC engagement 6200 rpm
    ECU code: PCT
    ECU Socket Type: OBD-2A(1996-1998 models) / OBD-2B(1999-2000 models)
    Note: This engine uses the same block as the Integra Type R (B18C5), which is taller than the B16a block (by approx 17 mm), but with a crank the same stroke as the b16a. It uses longer rods to accommodate for this, which is why the Rod/Stroke ratio is higher than a standard B16.
    الاقامة : egypt
    السيارة: bugattk
    السيارة[2]: bugatti
    K20A2 N/A swap
    https://www.youtube.com/watch?v=cOWmbicGun8
    EK Civic Sedan 2000:
    Running a stock never opened K20A2 and 6 speed manual transmission from Acura RSX Type-S. Also 3" exhaust, aftermarket intake, aftermarket header and intake manifold, 5 lug conversion for wheels, bigger axles, upgraded brakes and suspension, custom tunned ECU.
    K20A2
    Displacement: 1,998 cc (121.9 cu in)
    Compression: 11.0:1
    Power: 200 hp(147 kW) @ 7400 rpm
    Torque: 142 lb·ft (193 N·m)* (196 N·m) @ 5900 rpm
    Redline: 8000 RPM
    Revlimiter: 8500 RPM
    i-VTEC Engagement: 5800 RPM
    الاقامة : egypt
    السيارة: bugattk
    السيارة[2]: bugatti
    EK H/B
    K20 TURBO vs Kawasaki ZX-10
    K20 turbo hatch vs zx10 - YouTube
    Motor:
    K20a2 stock sleeve block
    Eagle rods
    wiseco 10:1 pistons
    Supertech valvetrain
    OEM headgasket
    Tranny:
    Stock 6 speed with New oem gears treated by racer steve.
    Comp stage 5 unsprung clutch
    comp flywheel
    Turbo:
    PLM manifold
    Tial 44mm wastegate
    Tial BOV
    Borg Warner S362 ETT .70 t3 housing
    hondata bbg solenoid
    precision intercooler with custom 3" ends
    xcessive bottom feed intake manifold with extensive porting
    Q45 90mm throttle body
    dual walbro in take full blown setup
    -8 feed -6 return
    Bosch 1600cc injectors
    aeromotive pressure reg
    golden eagle polished fuel rail
    -16 AN coolant hoses
    Brake line tuck with a wilwood 7/8 master, custom boost delete plate.
    Tucked clutch resevior
    Full wire tuck
    DSS 2.9 axles
    TX2K13: 700whp Cobra vs. 700whp Civic Hatch - YouTube
    TX2K13 700hp Civic, 800hp Supra, TT C6, Whipple Cobra, Fast Porsche, 383ci LS1 240 - YouTube
    الاقامة : egypt
    السيارة: bugattk
    السيارة[2]: bugatti
    ef9 4thgen
    b18c 2.0l
    civic ef b18c 2.L - YouTube
    b18c6 integra type r motor 2.l
    265hp at flywhel.stock itr gear box 4.785 with torsen
    95 MM CRANK 82 CP PISTONS
    port and polish head (b18c5)
    بالتفصيل كيفية تسقيط k20 فى الجيل السادس
    الجزء الاول قص و تركيب قواعد الموتور
    k20 swap part1 - YouTube
    الجزء الثانى قص و تركيب الفتيس
    k20 swap part2 - YouTube
    الجزء الثالث تجهيز و تركيب الموتور و الضفيره و العفشه
    k20 swap part3 - YouTube
    الصورة الرمزية abo-berry
    رقم العضوية : 111393
    الاقامة : ALEX, CAIRO
    السيارة: HONDA CIVIC SiR 1992
    السيارة[2]: HONDA CIVIC COUPE American Ex 2000
    الحالة : abo-berry غير متواجد حالياً
    ليه التعقيد ده !! :d: D
    الاقامة : egypt
    السيارة: bugattk
    السيارة[2]: bugatti
    اقتباس المشاركة الأصلية كتبت بواسطة abo-berry مشاهدة المشاركة
    700HP Civic Dominates on the Street! - YouTube
    الاقامة : egypt
    السيارة: bugattk
    السيارة[2]: bugatti
    k20(no turbo) head to head with evo 9 mr
    such a good run from a tuned 2.0L k20 DID MAKE EVO SUFFERED
    K20 Civic vs Evo 9 MR - YouTube
    الاقامة : egypt
    السيارة: bugattk
    السيارة[2]: bugatti
    clean as hell em1 si ride
    b18c inside
    Clean 2000 Civic Si EM1 with GSR swap - YouTube
    good ride em1 si
    b16a2 inside
    2000 Honda Civic Si EM1 0-125mph [Go Pro] - YouTube
    الاقامة : egypt
    السيارة: bugattk
    السيارة[2]: bugatti
    s2000 AP1 queen of high range rpm
    f20c inside
    9000... and this is legal!! - YouTube
    1,997 cc (122 cu in)
    177 kW (237 hp) @ 8,300 rpm (US & EU)
    184 kW (247 hp) @ 8,300 rpm (JP)
    208 N·m (153 lbf·ft) @ 7,500 rpm (US & EU)
    218 N·m (161 lbf·ft) @ 7,500 rpm (JP)
    8,800 rpm / 9,000 rpm
    87.0 mm (3.425 in) x 84.4 mm (3.323 in)
    cr : 11.0:1 (US & EU)
    11.7:1 (JP)
    16-valve DOHC VTEC
    6-speed manual
  1. Stunning Morgan Eva GT revealed
    بواسطة Mzeid في المنتدى Motors WorldWide News
    آخر مشاركة: 20-08-2010, 03:43 PM
  2. ECU tuning كليو 2
    بواسطة acer1400 في المنتدى ريــــنو
    آخر مشاركة: 13-11-2009, 03:17 AM
  3. Daewoo Car Tuning
    بواسطة MMamdouh في المنتدى دايــو+شيفرولية لانوس
    آخر مشاركة: 02-11-2009, 02:46 PM
  4. tuning برة و جوة
    بواسطة Amr_Moh في المنتدى ريــــنو
    مشاركات: 38
    آخر مشاركة: 10-10-2009, 11:36 PM
  5. Tuning information sieres-ENGINE TUNING FOR ALL CARS
    بواسطة SAbuhashem في المنتدى تعـــديل الســـيارات و الإضافات
    آخر مشاركة: 01-05-2007, 12:21 AM
