رقم العضوية : 3265
السيارة[2]: لانسر
I have noticed a Brake Judder when deaccelerating from 100km/h or higher,what's called hot judder.
I have checked the brake discs they seem to be fine.
could this problem occure because i didn't follow the bedding in procedure? or it doesn't worth to our street pads.
[shr71=http://pic.phyrefile.com/2007/10/20/jtte2o.gif]TG[/shr71]
رقم العضوية : 102
السيارة: Daewoo Lanos I 1999
دراجة بخارية: N/A
i had a similar issue with my car.... it was due to warped rotors
problem kept getting worse and worse till the judder was noticeable when braking @ 60 KPH
rotor replacement solved this issue, note that this could happen due to bad rotor material, age, washing car with water while rotors are still hot
