[youtube]http://www.youtube.com/watch?v=SZD2I21LU0I[/youtube]
رقم العضوية : 57
الاقامة : مدينة نصر
السيارة: هيونداي فيرنا
السيارة[2]: هيونداي فيرنا
دراجة بخارية: -
[youtube]http://www.youtube.com/watch?v=vGTy9cIG1xY[/youtube]
Frontal impact
64 km/h (40 mph) impact into deformable barrier. Simulates typical offset impact into another car.
4 Stars
Adult occupant protection
Frontal impact driver
Frontal impact passenger
Side impact driver
Child occupant protection
1.5 year old Child.........................None fitted
1.5 year Facing ..........................forward
3 year old Child.......................... None fitted
3 year Facing.............................forward
Safety equipment
Front seatbelt pretensioners
Front seatbelt load limiters
Driver frontal airbag
Front passenger frontal airbag
Car details
Hand of drive LHD
Tested model Mazda MX-5 1.6
Body type 2-seater roadster
Year of publication 2002
Kerb weight 1005
Comments
The MX-5 has had a recent facelift but the body and chassis remains much as it was when introduced in 1989. That being so, the car still proved safe enough to gain four stars, giving a well balanced performance in the frontal and side impact. The passenger safety cell was challenged by the frontal impact, however, and was found to be unstable, post-impact. In the frontal crash, the car was tested with its roof down to give worst-case results. For the side crash, though the top was left up to check for any risk of head injury that the driver might be exposed to. As a two-seater, the car could not be tested with child restraints fitted. While no crash tests were run to assess the safety performance of a child restraint, its fitting and labelling were checked. Finally, protection offered to pedestrians was poor.
Front impact
The airbag protected the driver's head. However, loads on his chest were relatively high. The car is designed so that impact forces are transferred underneath, through the sills and other structures. The doors are not designed to take any great load, front to back. Euro NCAP criticised this approach because there are accidents where the doors should help 'spread' the loads. The driver's and passenger's knees could cause suffer serious damage if they struck unforgiving components around the steering column and glove locker support.
Side impact
Loads on the driver's chest were relatively high (increasing injury risks) but were well distributed. Loads on his abdomen were also relatively high but the MX-5's overall performance was thought to be reasonable for a car without side airbags fitted as standard.
Child-protection
A system recognises when a Mazda-branded restraint is fitted to the passenger seat, disarms the airbag and switches on a warning. However this system will not accept non-Mazda restraints, which is hazardous if the driver is unaware of this. Warnings on the driver's sun visor were inadequate.
Pedestrian protection
This is a poor performance despite the MX5 benefiting from not having to have the leading edge of its bonnet tested because of its low profile.
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
رقم العضوية : 57
الاقامة : مدينة نصر
دراجة بخارية: -
[youtube]http://www.youtube.com/watch?v=l_khW088W-Y[/youtube]
Side impact
50 km/h (30 mph) impact by mobile deformable barrier. Simulates an impact from another car.
